 HElp with plane selection >
Old 06-05-2007 | 08:06 PM
Default HElp with plane selection
Hello all,
I'm interested in Sport Wings 90 from the wings maker
http://www.thewingsmaker.com/airplan...php?code=GA011
What I'm looking is for something easy to fly, stable, NOT very arobatic or fast flying plane.
What do you guys think about this plane from what you see in the picture?
Also do you think I can use a small Gas engine in this instead of 4 cycle glow?
Borna
Old 06-05-2007 | 09:44 PM
soarrich's Avatar
My Feedback: (98)
Default RE: HElp with plane selection
It looks like a nice plane, it looks like one of these would work well in one. I've flown two planes powered with it that where .90 size and it powered them well, and they ran great.
http://lsproengines.com/lspro_004.htm
PS I fly with LS of LS Pro Engines and have 2 of his 50 twins and a 100 twin, but I've flown the LS26.
Old 06-05-2007 | 09:57 PM
bigedmustafa's Avatar
This ARF looks a lot like a .90-sized version of the Super Sportster. You should be able to set it up with gentle control throws and a mildly pitched sport prop to get exactly the flying characteristics you're looking for. It also looks like it's just the right size for a 20-to-26-sized gas engine.
Good luck and be sure to post back here on how your project is coming along.
Old 06-06-2007 | 11:06 AM
jrf
My Feedback: (551)
That airplane is the World Models Super Sport Senior with different covering. It is a great flyer, but it is very light (read that as not very sturdy). It flies very well on a 91 four stroke. A 1.20 four stroke is way more than it needs. (I have flown it with both, including on floats with the 91.)
A gas engine won't fit inside the cowl, and you would probably have to reinforce the fuselage to handle the vibration. Not to mention the balance problem.
It's a very nice airplane, just not very appropriate for gas.
Jim
Old 06-07-2007 | 06:14 PM
Thanks for the info. I was not aware that this was World Models Super Sport Senior. I search on World Models Super Sport Senior and found out it works well with Gas engine
http://www.rcuniverse.com/forum/m_159552/tm.htm
Old 09-12-2007 | 06:51 PM
goplaneman's Avatar
My Feedback: (175)
Well, did you buy the plane and put a gasser in it?
Old 09-12-2007 | 07:01 PM
Yes I bought the plane. and got to tell you that is a nice plane. I haven't build it yet because I was busy converting a GMS 120 glow engin to GAS which I'm going to use it for that plane. See the engine and the conversion process at
http://www.rcuniverse.com/forum/m_61...tm.htm#6165393
Borna
