H9 1/4 Cap 232 assembly help.
Howdy people...I'm getting ready to 'assemble' my 1/4 Cap (got an OS 1.6fx w/ bisson pitts...whoohooo!!!) and I'm running into some firsts for me. I've put together quite a few Arf's but have never sealed my hinge lines. I understand the reasons for sealing, and the general idea, but how do you do it? The one method I have heard seems a little arduous...it is to take a piece of clear tape, fold it down it's length, move the control surface (aileron, elevator, etc) to it's furthest point, and lay the tape into the gap, press it in, and cut off the excess later. Is this right? Is there an easier way? I also vaguely recall reading an article whree a guy ironed a small strip of covering to the wing and let it lay flat on the aileron..(didn't iron it to both surfaces...allowing the aileron to move)
Next question...The instructions for the CAP say to use standard servos. Can I get away with this? Thanks.
Tracy Mettler, Ketchikan Alaska
Ditto to rocketman. I've done it with tape and covering. Tape works, but....it's a major pain compared to covering, and it usually ends up peeling off too. I like to use a low temperature covering to help eliminate bubbling, but it doesn't come in clear. Go get a roll of clear monokote just to have around for sealing hinge gaps.
Banned
Re: H9 1/4 Cap 232 assembly help.
I prefer JR servos... but they're more expensive.
I use 605s every place but the rudder.there i use a 615 metal gear.Use a 5cell rx pack and the 605s put out over 90 in lbs(acording to my dealer)seal all surfaces(i use clear ultra coat),good luck
