 Need help fixing ParkZone 210 Cessna >
Old 11-30-2007 | 09:07 PM
Velocity-8's Avatar
My Feedback: (15)
Default Need help fixing ParkZone 210 Cessna
I bent the prop shaft on my PZ Cessna 210 and it doesn't look like the shaft is removable. Anyone know how to replace the shaft or do I need to replace the entire gear/motor assembly?
Thanks!
Old 11-30-2007 | 09:55 PM
Mr. Mugen's Avatar
Default RE: Need help fixing ParkZone 210 Cessna
Try asking in this forum instead. It is geared toward indoor micro flight. Kevin
http://www.rcuniverse.com/forum/forumid_182/tt.htm
Old 11-30-2007 | 10:23 PM
Velocity-8's Avatar
My Feedback: (15)
ORIGINAL: Mr. Mugen
Thanks. Sorry if I posted in the wrong forum.
Old 12-01-2007 | 12:45 AM
My Feedback: (7)
A quick search on Horizon's website found this:
http://www.horizonhobby.com/Products...ProdID=PKZ3028
Old 12-01-2007 | 08:41 AM
Velocity-8's Avatar
My Feedback: (15)
ORIGINAL: I_Fly_Coolers
I know that the gearbox is replaceable and I already ordered one from Red Rocket. My question was if the prop shaft was replaceable without replacing the entire gearbox.
Old 12-01-2007 | 08:54 AM
can you post i pic i have one and love it . You do know the prop is supposed to have a lot of downthrust. A pic and we can get ya flying again
Old 12-01-2007 | 09:42 AM
Velocity-8's Avatar
My Feedback: (15)
ORIGINAL: timothy thompson
The problem is I bent the prop shaft which is causing the gears to bind. If I can get the prop shaft off I can probably straghten it out. If not then I'll replace the gearbox (I ordered one anyway).
The bushing on the prop shaft doesn't want to come off too easily and there is no set screw. I'm not sure what it holding it on.
Old 12-01-2007 | 10:11 AM
the replacement is the best way its cheap. it order several more and a couple batts for insurance
