H9 73" wingspan Cap 232 landing question
When I come in on final for landing and reduce power, the nose of my H9 73" Cap 232 tends to rise. This causes a rapid decrease in airspeed. Could the cause of this be either tail heavy or need some down thrust?
Ed
Ed
My Feedback: (23)
Mr. Ed..... (I assume this is not the horse !!... of course!!)
try inverted flight , if the plane climbs you are most likely tail heavy. down thrust will make it worse. many cap's land rather "nose-high" especially when balanced toward the rear of cg.
My Feedback: (13)
My 33% Cap did the same thing, even though it wasn't tail heavy. I think it's a thrust line issue.
To counter this, I put in about 5% down elevator on my transmitter landing switch. It activates at about 1/4 throttle and below. It helped a great deal.
John
John
Mine did the same thing. I think aerobat66 is right; it is a thrust line issue.
At first, I just kept the power on and flew it all the way down. Then I tried playing with my 9Z's Airbrake function (spoilerons mixed with elevator), and that was the trick.
Steve
Steve
My Feedback: (13)
Thrust line
Ed, I went back and read your original post again. I think down thrust would make the problem worse. With power on, the engine would be pulling the nose down. When you reduced power, that force would diminish, and the nose would rise. If anything, up thrust would help the landing problem, but it would likely cause other tracking problems during the rest of the flight.
I haven't tried the spoileron trick, but it sounds like it would help. I just couldn't get used to pushing down elevator five feet above the ground. With the down mixed in, I'm actually holding neutral, or even pulling the stick back a little, which feels much more natural.
I would suggest you try both the spoileron and down elevator mix, and see which one works best for your particular setup and flying style. Keeping the power on until you actually start the flare works too, but it's something you have to make into a habit.
John
John
My Feedback: (54)
Trim for straight and level flight. Fly past yourself at full throttle and then abruptly chop the throttle. If the nose rises, you need more upthrust. Most CAP's require from 1/2 to 1 1/2 degrees up to behave themselves. I added up to my Midwest Little Cap and my H9 CAP, like yours, and it helped both of them. Also had a friend with an Ohio RC CAP and he did the same thing.
Rein
Rein
