Post type controls horns? >
Old 03-06-2002 | 08:25 PM
My Feedback: (25)
Default Post type controls horns?
I have been looking at the post type control horns and they seem to be really a lot easier to install and use than the standard 4 screw horns you see on everything. I want to put these on a 1/4 scale Cap if they are good for this purpose. Can someone comment and give me a source and size for my plane that would be appropriate. thanks.
Old 03-06-2002 | 09:24 PM
HI Splais,
Central hobbies have them.
www.centralhobbies.com
also rocket city use to make them, you can still find them but its getting harder. I use them on my 1/4 scale edge.
good luck!
aschuck
Old 03-06-2002 | 10:00 PM
My Feedback: (25)
Awschucks, I talked to Central hobbies. they thought they were two small (diameterwise) for 1/4 scale. Have you noticed any tendency of yours to bend? thanks.
Old 03-06-2002 | 10:24 PM
I'm installing the rocket city one's.
This weekend will be it's first flight.
Central hobbies looks stronger then the rocket city, but I think they will do fine, I hope. I'll let you know this weekend!
Old 03-08-2002 | 06:23 PM
My Feedback: (10)
I get mine at the local hardware store. In my case it is a HomeDepot. I buy the size bolts and blind nuts I want- 440/632/832/1032 or whatever,and blindnuts, washers, etc. I use the stainless ones. I cut the tabs off the blind nuts and reverse them on the bolt that is mounted through the surface. The head is ground/cut off the bolt of course. Could use locknuts instead of blindnuts. One nut on the top surface, one on the bottom. I make sure there is a good solid/firm surface to put the bolt/control horn through. A drop of ca or locktite is applied. I use pull/pull on elevator and rudder whenever possible. No problems so far in several years.
