 Should i be concerned? >
Old 07-15-2008 | 06:37 PM
MetallicaJunkie's Avatar
Default Should i be concerned?
Ok i have a show time that flew well with a 61FX, since i opted to use a pitts muffler, i made it a side winder, instead of using the stock mounting method at 45 degrees, I plan on putting a saito 91 using the same motor mount, sideways. Would the model fly any worse/better having it mounted sideways vs 45 degrees like the manual calls for?
Old 07-15-2008 | 07:13 PM
tailskid's Avatar
My Feedback: (34)
Default RE: Should i be concerned?
Shouldn't make any difference! Enjoy it
Old 07-15-2008 | 07:50 PM
SunShyne's Avatar
My Feedback: (68)
ORIGINAL: tailskid
he is correct, slap it on and enjoy
Old 07-15-2008 | 09:16 PM
ram3500-RCU's Avatar
My Feedback: (221)
I prefer 90deg with 4-stroke engines. It will be fine, providing your take is in the right place for the carb location.
Old 07-15-2008 | 09:53 PM
ok..... the carb is a little above the fuel line..maybe by a centimeter so that means ill have to richen the low end? i plan on running it on the ground tomoorw
Old 07-16-2008 | 01:59 AM
My Feedback: (221)
I like my tanks center on the carb on my Saitos so they run the same inverted. Could be a challenge when one changes engines. Hope it all works out for you. I'm sure it will. The 91 is a good engine IMO.
