Great Planes Escapade .40 ARF
#1351
RE: Great Planes Escapade .40 ARF
As a guy who would like to move on to his second plane (badly!), what other planes would all of your recommend? I'm looking for something with similar flying charactertistics of that of the Escapade, except one with out all of the issues that this thread has identifed. I simply want to fly, and not deal with so much hassle. I have to admit, I lack building experience, but I'd like to rely on something thats tried and true. Thanks againg for your attention.
#1352
My Feedback: (10)
OR
The Escapade has NO Issues. If assembled per the directions and Tech notice it is a great plane. As best as I am able to surmise the people who think the plane needs modifications either do not understand the value of a light aircraft, or overpower or exceed the airframes design, or are just hard on the plane due to a lack of experience.Assemble itas designed and you will not have any Issues.
#1353
CA
As said previously this plane does not need to be modded! Does not need any alterations (tailgear or main landing gear). Just fly it and have a blast. Put a O.S. 46ax in it, no added weight is needed.If you have problems with the landings work on the AOA with an instructor. For a hundred dollar airplane this thing is well built.
#1354
1 Post
AS all have stated above, this airframe has no vices.
I never did bother to reinforce the tailfeathers It never fell offm but then I don't fly kamikaze.
its a very good quality ARF at a very affordable price.
It likes some power on landing but it can be floated to the ground as well.
If the pilotis not comforatble landing an Escapade then most likely they left their trainer behind too early
#1355
ORIGINAL: prelude92
Thanks, Hsukaria. How long ago did you purchase yours? Just wondering if perhaps you got an improved model.
jc
jc
I did my last flight of the season yesterday with my Escapade. I got only one flight due to changing weather. It was a beautiful flight, the landings were perfectly smooth since the wing loading on this plane is just right, not too light for windy conditions, not too heavy to make landings difficult.
With a Super Tigre 51, I did not have to add any balancing weights either.
#1356
ORIGINAL: prelude92
Some of the issues you read about with problems had to do with guys doing power dives with it and breaking the elevator joiner (which I hear has been beefed up by Great Planes). Power dives are not recommended for any airplane, including the Escapade. Maybe some racing planes can take power dives, but for general flying, that is not good practice.
#1357
ORIGINAL: prelude92
#1359
ORIGINAL: hairy46
A Stik is a great 2nd plane! They are allot of fun fly great and land slow! Good luck with your choice!
#1363
NY
I've been thinking about getting the escapade with as os 46ax. But, recently, i thought about maybe putting in a 4 stroke instead of 2s. Either the Magnum xl52rfs, or the xl70rfs. Now i never ran a 4 stroke engine before, and was wondering if operating a 4s is more difficult. Also which Magnum would be better. Thanks
#1364
My Feedback: (10)
OR
The 52 will fly it just fine. Four strokes are not any harder to operate. Just read and follow the instructions that come with the engine and you will be fine.
#1365
I was doing some aileron rolls today with the Escapade and suddenly it became a convertible model. The canopy fell off. Tommorow I will search for it if not I'll have to order one.
#1366
CA
Ah bummer.Fortunately I havn't had this happen to me but could I am sure. Good luck with the find, tomarrow should be a good fly day here so me an the escapade and rv-4 should make it out for some fun.
Tim
Tim
#1367
When I built mine, there was an Assembly Manual addendum where they wanted you to put 2-3 layers of foam tape on the front of the cowl to act as a 'spring' to keep the cowl in place. I wonder if yours didn't have that addendum,
On another note, I cracked mine up on the maiden... My fault. It got into the air once but the throws were a little touchy. So, I brought it back down and readjusted them a bit. On the next takeoff, just as she was getting 'light' on the wheels and I was about to give a little 'up' elevator, she hit a divot and cartwheeled. The fuse broke right across the firewall former. No easy way to fix that without making it look ugly.
She had some nice spirit with that Axi 4120 and the 4S 4200 mAh battery. Can't wait to get her into the air again...
Bob
Bob
#1368
The plane was assembled as per the manual, it had the foam tape in place at the time of separation. What I think what happened was that the canopy was not making solid contact with the magnets. I looked for it today with no luck. I'll order a new one andput some type of tape or velcro at the top so it doesn't fall again.
#1371
I'm looking for anyone with a canopy for the Escapade who is not using it(crashed airplane etc). No store has them and they are going to be received by late December or January. Any help will be greatly appreciated.
#1374
NY
Oldvet
Does the XL52 have similar power to the OS46AX. Or would the XL70 be a better choice. I ask because my friend has the OS46AX in his escapade, and the power of that engine, seems to be just about right. I would go with the OS, but i want to try something different.
#1375
My Feedback: (10)
OR
Bladebuster,
The 70 gives you an engine similar to your friends 46AX but the 52 will fly it fine. My wife has one with a 46FX and I put one together for an older fellow with an OS 25FX, it flew just fine and at a speed he prefers. Someone on here has one with an Irvine 36, which would be similar to the 52 and he says the 36 is plenty of engine. Like I said the 70 will be more like the 46 of your friends.
