Nitroplanes Extra 330
My Feedback: (-1)
May I be redeamed in my next life, my hands touched and ARF and I'm A little impressed with it. Not A lot but A little, OK, maybe A little more then A little.[&o] I'm assembling the NP 90 size Extra 330 for A student and was wondering if anyone has assembled one with duel elevator servos?? In my Chinglish instructions they are showing A drawing in #4 VerticalHorizontal tail Double push and push rod then state This part needs to buy separated see 5 below?? My question is are there hidden servo mounts under the covering? I don't want to be cutting the covering just to find that voided area I can feel under the covering is just A die cut hole. I'm begging to like this ARF, the instructions keep me laughing!!!
Busted my wife up too after she had A bad day at work. The kid can have the plane, I'm keeping the instructions!!
Don,t use it for a lawn dart just yet
, maybe someone will chime in. Maybe you can look down insde the fuse with a small mirror...and a lite! Capt,n
G'day. There was a small thread on this a while back in the 3D section. The same question was asked on page 2.
http://www.rcuniverse.com/forum/m_52...a%2C330/tm.htm
Read the thread - there is some really interesting hints that will save you a lot of time. Overall - I was very impressed with this model and the way it flies.
Good luck.
Good luck.
My Feedback: (-1)
bjor, thank you for the thread. That's what the picture in the book looked like, just the duel rod linkage set up but I did hope they set it up for the two servos. The kid can have A carbon fiber rod with A Y because I don't feel like going across town to the hobby shop that has the system in stock. Cap, I did give the old mark one eye ball and A light A try first thing but it's A long narrow path to the back. I'm surprised at how well this ARF is built, A bit light for my taste in A few places but A few sticks and some glue will fix that. The fuse sides squish in A bit when you install the wings but that should be OK after they are put on and off A few more times. Too bad my pockets are empty or I would have me A couple of there planes just in case I needed A plane in A hurry. No place to store A box this size either. Wonder how big the 50cc planes box is?? This box is huge!!
