Great Planes Extra 300 GP/EP
#327
FL
RE: Great Planes Extra 300 GP/EP
Definately is... makes me look like a good pilot. Also, the CG location can totally change this plane around.
Forward, and its a docile everyday sports flyer...
Back, and this thing hits its prime...
Its about 4-5 mph faster w/the weight in the back; this I later found out that this was due to less drag and weight on the wings, and a bit more on the stabilizer (according to an aerospace engineer) who knew right??? And it becomes an excellent 3d flyer with the weight in the back. This thing is well worth the money!
#328
SC
Hi guys, Here is my dilema... i have a .46AX, .55AX, FS70s-II, and a FS91s-IIP. My question is which one to use in my Extra. I have done the research and it is as such....... .46AX ([email protected] and weighing 17.2oz) the .55AX (1.75hp.@16000rpm-9cc./eng wt.14.3oz. minus silencer weight), FS70s-II ([email protected]/20.4oz.), and the FS91S-IIP ([email protected]/23oz.). I want the best power to weight ratio without compromising weight. I do fly IMAC, 3-D style, sport, and freestyle. In my opinion, I think the .55ax is the best all around choice. even better than a .81FS. But another problem I have is the bhp. compared to the cc. of these engines. Is it better to have more hp or more cc ?!! WILL THE .55AX PULL IT OUT OF A HOVER ????!!!!!!!!!
#329
SC
I was wondering if someone could post some pictures of the .91FS installed, and also how it looks without and with the cowl on. Also, what type of exhaust did you use. I have a pitts inverted for my .91FSIIsP
#330
AL
Hey Raden , I'm running a .82 and this engine is more than enough power for anything the plane can handle. Full power only when in trouble.
#331
My Feedback: (13)
NE
ORIGINAL: raden201
You will enjoy this bird.
#332
raden201 -
If you peek at pg. 5 & 6 of this thread you'll see a pics of how I installed my OS 91 FS into the extra. I used all stock parts, no pitts muffler and it worked out just fine. I had to cut a 2" square exhaust 'vent' on the bottom to avoid overheating of the engine but, it all fits just fine with room to spare. Personally, I don't see a need for a pitts as the muffler's going to hang out 'ugly' one way or another. But that's just me....
Cheers!
#334
which prop are you using with the 55ax?
I'm maidening mine very soon with 55ax and standard muffler.. have a 12x6 on it currently..
#335
ORIGINAL: ceecrb1
#337
not sure who's you want to see.. so heres mine as a starter.
Still waiting for LIPO & BEC, pilot figure and rudder servo... then set the C/G.
As you can see I obsess over organised installs.. so all fuel line and cabling is braid coverd and numbered.
I also used a credit card to open an cooling vent on the underneath of the cowel.. the cut-out was then glued to the inside of the fuse to camoflage the opening a little.
#338
Gents -
Needless to say I'm getting upset reading your dialogues regarding 'maiden' flights and noting where you are all from.Currently it's -9F below with a windchill of -24F below. I seriously need to move.....MN-ota weather blows (and I can say this cause I've lived here 30+ years).
Nuff said. On with the Extra EP conversation....
#343
ORIGINAL: kq4ra
What are you talking about?
Then again when spring comes around it's that much nicer to finally get out there flying under the warm sun. Should have my gp extra ready by this spring
#345
kq4ra / CloudSkipper / Turboprop130 -
Yes, it was a complete toung-in-cheek comment about Turboprop130's ability to fly year round in great weather (nice pic Turbo - looks like a great place to hit the skies). I mean, who wouldn't like good weather year round in this hobby. I'm just jealous is what it amounts to. Hehehehehe
#346
AL
I am trying to post some pics of my 300, but the files are too large to send. I don't know how to reduce the file size to send them.
The famous weather man is predicting snow here for Thursday, maybe put the skis on the foxbat and go fly.
#347
Open the files with Mspaint.. then sellect "image" then "resize /scew" and reduce in percentage incraments...
try 33% or so?
try 33% or so?
#348
ORIGINAL: kq4ra
#349
I need more pictures to inspire me to get my gp extra assembled (I haven't started it yet... arg). Try in MS Paint: Image->Resize/Skew. And make sure to save-as JPeg.
