Reload this Page >
Top Flite Cessna 182 ARF
Old 04-30-2016, 07:17 PM
  #1326
alfawaz
The stands are awesome they are brand new one of the club members just made couple of them for the club .. I guess you could find the plans on AMA's website and they shouldn't be very expensive to build. As for the engine you could not have asked for a better timing I just took the cowl off in order to tune the engine a little give a while I will go to my shop and take a picture for you. Any specific details you want to see so I could get them for you?
Old 04-30-2016, 08:16 PM
  #1327
dkurtzid
Very nice!
But I have to ask about your flying site. Is that the clubhouse with an observation deck and all? Bleachers too?
Don
Old 04-30-2016, 10:26 PM
  #1328
alfawaz
Originally Posted by dkurtzid
Very nice!
Don
Hi Don
Thank you !! Yes this is our field The Iowa City Aerohawks located in Iowa City,IA
Yes we have a heated club house, electricity inside the clubhouse and outside in the pitts area for charging electric and any other uses and a fabricated runway. The bleachers are used for spectators, because pitts area is only for pilots and club members. Moreover, we have an " Air Show" every year in September where we have around 1500 people attending. Attendance is free and the program includes 3D, Jet, scale, warbirds, trainer review and such event. You guys all are welcome to attend if you are around the area. Here is the website of the field
http://www.iowacityaerohawks.com/
and here is the facebook page everyone is welcome to join
https://www.facebook.com/groups/6839563492/
And here is an aerial view of our field.
Abdul
Old 04-30-2016, 10:49 PM
  #1329
Twin_Flyer
I just want to see how you mounted it.
Haven't flown anything with gas yet so still learning...
Thanks!
Bill
Old 04-30-2016, 11:11 PM
  #1330
alfawaz
Hey Bill
It is not that hard to be honest I used the same mount included with the airplane it mounts just like a glow, however if you go to bigger size gas engines you usually use standoffs with recommended lengths for the specific airplane you are using.
ID:	2160290   Click image for larger version
ID:	2160291   Click image for larger version
ID:	2160292   Click image for larger version
ID:	2160293   Click image for larger version
Old 04-30-2016, 11:13 PM
  #1331
alfawaz
This is a picture I got off of google with an engine mounted using standoff
Old 05-01-2016, 09:35 AM
  #1332
Twin_Flyer
Perfect!
I will probably use my dle 20 as I don't think the G23 will fit as well.
Bill S>
Old 05-01-2016, 07:20 PM
  #1333
alfawaz
You got it
Abdul
Old 05-04-2016, 12:37 PM
  #1334
drdoom
My Feedback: (9)
How well does the DLE 20 RA fly this Cessna 182? I have one with an ASP 160 glow, but want to go gas.
Looks like it will fit in without any severe cutting of the cowl.
Old 05-04-2016, 12:47 PM
  #1335
drdoom
My Feedback: (9)
Originally Posted by alfawaz
Hey Bill
Did the engine mount the original mounting holes or did everything have to be drilled and fitted. was the original firewall mounted OK? Can I ask what prop you are going with.
Old 05-04-2016, 01:24 PM
  #1336
alfawaz
Hey Drdoom
The mount didn't have holes in them I just put the engine on it marked where they are supposed to be then used a tap and drill and made the holes. You just need to make sure to get them dead center because one of the holes I made wasn't the best so had to enlarge it a little but with the locknut it is just perfect. I had to trim the mount a little though but not a big deal. The prop I used on the maiden was probably 15x7 or something but I will double check once I get home. I think 15 is the largest to clear if I were to use a 16 which the engine could handle easily I think it will be hitting the ground or come really close.
Old 05-04-2016, 03:37 PM
  #1337
KaP2011
My Feedback: (17)
KaP2011's Avatar
I believe the holes Drdoom is talking about are the factory drilled firewall holes. As to how well the DLE 20 RA will fly this Cessna 182, mine has an OS 95v 4 stroke and fly's with authority. This Cessna is designed to fly with an engine as small as a .61 2 stroke with a 1.20 4 stroke at the top of the engine range.
Old 05-04-2016, 05:37 PM
  #1338
alfawaz
The mount is adjustable with the 20 you have to use it as wide as possible so when adjusting it you will notice you will have to use the widest setting in other words it is not an issue. As for the power as Kap2011 mentioned this airplane was designed around a 0.6 ci two stroke engine the 20cc is equivalent to 1.22 ci which is the double of the 0.6 it flies the plane with authority you could have it do whatever you want. I will have to mention it would be a good idea to reinforce your firewall. I haven't had issues with that but other members on the thread advised me to do so because some had their firewall break. What I did is went over the the joints with thin CA then used 30 minutes epoxy and covered the whole fire walla and the motor box .. so far so good
Abdul
Old 05-04-2016, 06:28 PM
  #1339
Twin_Flyer
I wonder how well a 15" three blade prop would work on the DLE if a two blade 16" would have clearance issues...
Bill S
Old 05-04-2016, 08:03 PM
  #1340
alfawaz
I bet it wouldn't be the best. The one I have on is actually a 15x8 and if I have just a little bit of a bad landing it would definitely hit the ground therefore I think a 14 or 13 would be better. I just ordered a 13x8 and hopefully that is going to be good.
Old 05-05-2016, 08:23 AM
  #1341
drdoom
My Feedback: (9)
You are correct, I was asking about the drilled firewall holes. the DLE 20 Ra is a drop in fit. only took minutes..
Old 05-05-2016, 11:05 AM
  #1342
alfawaz
Awesome how do you like it ? need any help?
BTW try to insulate the landing lights cables .. the heat of the engine melted the right one I need to do something about it.
Old 06-02-2016, 08:39 AM
  #1343
Erwin Z
hello everyone,
I am building my C182, the manual dont say anything about the lighting system, do you guys know what is the max voltage those lights can handle.
Old 06-14-2016, 01:27 PM
  #1344
drdoom
My Feedback: (9)
I have flown the Cessna with the DLE 20RA and it is a great combination. lots of power and will fly forever. Our runway has some asphalt that is coming apart and I got one of the wing tips in the ground. severely scuffing the right win tip clear plastic lense. TF doesn't sell just the light clear cover so I made a set. came out definitely usable
Old 06-28-2016, 06:50 AM
  #1345
drdoom
My Feedback: (9)
^ flights on this bird Sunday it will fly all day and beg to be flown more. Just like the real thing.. Thank You Top Flite might be the perfect model. Now do a Cessna 177B Cardinal. 1/5th Scale Please...
Old 02-11-2017, 12:15 PM
  #1346
JFEsch
How are you attaching the nose gear fairing to the strut? What is your measurement from the swing arm to the top of the strut?
Old 02-11-2017, 01:15 PM
  #1347
elmshoot
How about this for a a 177?
Old 02-19-2017, 03:25 PM
  #1348
tigerdolly
Hi-
I am thinking about using an os 95, also. Could you post a few pics of your setup? Thanks.
Old 02-19-2017, 05:36 PM
  #1349
tigerdolly
Originally Posted by Skytraxx
Fellas, I've built two of these planes and the easiest way to solve the weak firewall mount and forward and aft issues is this...
If you take note of the recess in the bottom of the firewall and the way the stock coil spring sits in there, you will notice that the spring coil will touch the firewall when minimal forward pressure is applied, that in turn supports the nose gear shaft and makes it actually quite forgiving on the rough landings. If you install the Robart gear just epoxy a block into that recess and notch a nice groove in it up and down, allow minimal clearance between the groove and the shaft of the nose gear and it will take a pile of abuse, believe me I know!! It works great!! I will post pics soon
Hi-
Did you ever post pics of the mod?
Did it stop the robostrut from bending?
Thank you.
Old 02-20-2017, 05:40 AM
  #1350
KaP2011
My Feedback: (17)
KaP2011's Avatar
Originally Posted by tigerdolly
Hi-
I don't have any pictures of my setup. The OS 95v was mounted inverted, pretty much everything was in side the cowl except for the front of the engine and tops of the valve covers. The two pictures I've attached are of my first Cessna with a Saito 1.00, I swapped it out because of vibration and put in the 95V. The only change I made was to open the air hole in front of the cylinder head. An APC 13 X 8 sport prop looked very scale when painted so that is what I used on both engines.
ID:	2201934   Click image for larger version
