 E Z  Arf Models >
E Z Arf Models
E Z Arf Models
Old 06-21-2017 | 11:18 AM
  #376
nice find!
i dug out my old Diablo to do an R&R on it so i can fly it this season.
All new fuel tubing, stopper and brass lines.
Needed to order a rebuild kit for the fuler as the internal O ring turn to stone. once i have those pieces its ready to go.
Was tempted to swap the YS 120 for a DLE but it didn't fit the mount so decided to skip it.
ID:	2221085   Click image for larger version
Old 06-30-2017 | 07:25 AM
  #377
Thumbs up EZ Mustang
Just came across this thread and dug this out of the loft
ID:	2222434   Click image for larger version
Old 07-06-2017 | 10:03 AM
  #378
I have a 40 size EZ biablo with an Italian 51 super tiger engine
one great flying 40 size airplane
the fact it is still around and flying after all these years is the proof of how well the EZ kits fly
plane needs only your rec and a battery to fly
Building and Flying two cycle glo for 23 years more than most
you can see the plane in my Galley on the left of this post
i am located in Central Florida
local pick up only
Down sizing so $200
Tony 1-352-607359
Old 07-06-2017 | 01:30 PM
  #379
Default EZ Cap
I dug this one out. $295 shipped
It kills me but GA is killing me too!
ID:	2223244   Click image for larger version
ID:	2223245   Click image for larger version
Old 08-18-2017 | 07:18 AM
  #380
Default Looking to buy Hobbico or EZ Extra 230-25 size arf
Does anyone know or have a NIB Extra 230-25 size ARF that they are willing to sell and ship to Va.
Use to fly some back in the days and got the itch to find and have one again.
Thx
Terry
Old 08-21-2017 | 06:37 PM
  #381
Default EZ Reno L250 or M250
Looking for a pair of Reno Racers from the early 90s. I realize these are rare and will offer top dollar for NIB.
Old 09-08-2017 | 05:58 PM
  #382
CaptRKO's Avatar
LOOKING FOR the 1/3.8 Christen Eagle I.
PM ME ASAP !!!!!! Any leads appreciated!
Old 09-17-2017 | 12:26 PM
  #383
jeffie8696's Avatar
Can anyone identify this one for me, appears to be 25 size. It has the classic EZ construction and maybe looks like an Sbach?
Old 09-17-2017 | 05:40 PM
  #384
Jeffie8696, I'am gonna guess....."Tequila Sunrise" by Global Models from about 15 yrs ago.
Old 09-18-2017 | 09:55 AM
  #385
jeffie8696's Avatar
It is so old moldy and beat up I just call it Krusty.
Old 10-01-2017 | 02:57 AM
  #386
Default EZ Diablo information needed!
Hi, I've been given what I believe is an EZ Diablo, wingspan around 92". The history is it last flew in about 2005 when it crashed, destroying the front of the fuselage. The owner acquired a new fibreglass cowl and fuse which he joined to the original tailplane. The new fuse is a bare shell and I'm looking for information as to what is required to get the model flying again. Does anyone have any old build instructions, plans or pictures please?
Old 11-28-2017 | 11:15 PM
  #387
My Feedback: (65)
Default EZ P-51 Mustang 30
Finally after almost a year I’ve managed to get a few flights on this bird and worked out a kink here and there. Changed the wheels to some standard du-bro wheels as the foamies just didn’t offer any cushion at all. Brought the elevater and aileron control throws waaay down from recommended. Then I changed over to a .32 from the old FSR .28 Big difference in flight performance. The old .28 runs phenomenally but the newer engine just has power advantages. Actually a perfect combo now. I also clipped 3-1/2” from each wing panel and made some new wingtips. I did this because the wing is too wide scale wise and it floated too much on landing. I only intended to remove 2-1/2” but oh well. Now it doesn’t float so much and comes in for a nice wheel landing that sticks rather than tend to float and bounce.
Being that EZ marketed this as a “P-51D” they kept things simple though. For example the wings leading edge is straight and has no kick forward at the root like the A,B,C,D,K series. It’s actually like the “light” mustang variations that led to the “H” model. So that being said I decided to go forward and make it look as much like the H as I could. Made some H model gear doors. Then I removed the vertical fin cap and built taller one from balsa again to simulate the H model vertical.
That’s as far as I’ve gotten for now. I decided on the “NACA” mustang scheme with its yellow fin stripe to keep things simple. Previous owner painted the nose so it’s gonna take some work to remove it but it’ll be a decent looking little mustang when all is said and done.
I’ll post more pics as I transform it to the finished scheme.
ID:	2246494   Click image for larger version
ID:	2246495   Click image for larger version
Old 11-29-2017 | 03:06 PM
  #388
SHANEC's Avatar
Nice!!!!!!!!!!
Old 12-01-2017 | 07:37 PM
  #389
My Feedback: (65)
Well....about 2 hrs of rubbing and wiping with acetone then some masking and painting. Kudos to my wife for knocking out the “NACA” decals on her Cri-Cut machine!!
Just a few more decals for the fuselage and that’ll do it.
ID:	2246649   Click image for larger version
Old 01-03-2018 | 07:24 AM
  #390
Jaws,
I'm working on an rpm ez 1.8 glider with creases in the fuse. Have you had any luck unwrapping the fuses from the bottoms?
Old 01-03-2018 | 09:33 AM
  #391
My Feedback: (65)
I've never really attempted to as it just hasn't come my way yet. Although recently I used a monokote iron on low heat and was able to remove some shallow dings and dents with some success from the surface of a wing. You can give that a shot and try varying temperatures to see if you have any luck.
Best of luck to ya.
Old 03-17-2018 | 02:15 PM
  #392
My Feedback: (65)
Default Ez reno l250
This one has been waiting a while so thought I’d get it ready for the flying season. Bought it started but was missing the cowl. I may build one later for it but for now it’s fine. I used a tried and true engine setup that had been on an old blue version I retired long ago. K&B 3.5 on a pipe with a reworked Zinger 8 x 6. Great combination on this little bird.
Old 03-23-2018 | 08:01 PM
  #393
Default Looking to buy ez kits
Hello guys .I am looking to buy the ez christen eagle .or any ez airplane anyone selling anything .just let me know .or call me at 513 815 2158.…..tommy .
Old 03-30-2018 | 01:47 PM
  #394
I have the Dallas Doll but no instructions ,would you send it to me or copy of it please. ian Hindmarsh ( spitfire mk24)
Old 03-30-2018 | 01:54 PM
  #395
i have the EZ Dallas Doll but no instuctions,can you send your to me or copy them please. Ian Hindmarsh (spitfiremk24) [email protected]
Old 03-30-2018 | 02:31 PM
  #396
Dear Sir . I have the EZ p51 Dallas Doll arf but no instructions with it, could you send me the instructions or tell me where I can get them thank you. Ian Hindmarsh(spitfiremk24) [email protected]
Old 04-18-2018 | 10:44 PM
  #397
My Feedback: (65)
Default Another ready to test
Bought this modified Dago Red from an estate sale a while back. Previous owner did a great job putting it together and Id say he didn’t fly it much. Was set up with a 46 but I dropped in an OS 61 SF with the topflite in cowl muffler. Really cleans the lines up with out butchering the cowl. This is actually a great power set up for the EZ Mustang if you like two strokes. I’ve had a dago with an OS FS 91 four stroke and that’s a great combo as well. My next mustang will be with a YS 91 or 110 depending on what I have available. Curious to see how that will perform.
Old 04-26-2018 | 04:38 PM
  #398
radpilot's Avatar
I like it just bout a B model i see you have one in the background would be kind enough to take a picture of the CG location if you have the manuel . i hate to set it wrong on this rare kit
Old 05-02-2018 | 01:14 PM
  #399
My Feedback: (65)
I have the instructions in PDF for the Dallas Doll / Blue version. Instructions are almost identical for the B model and Dago Red with the exception of a few insignificant details like canopy and such.
But for whatever reason I cant post them here because of some security issue so if your wanting them just give me your email and I will forward them to you.
Paul
Old 10-21-2018 | 01:47 PM
  #400
My Feedback: (65)
Default Newest EZ Mustang
Wanted to do something different as far as schemes go. Unfortunately with this particular model the invasion stripes and stars are printed in the skin so no real way to get around them other than covering them up with silver vinyl so chose Bud Anderson’s Old Crow. His didn’t have the invasion stripes on top of the wing but what the heck....got to compromise some right?
YS FZ 91 on this one as I’ve never tried this combo. Just a touch heavier than using an OS 91 (which I think is a perfect combo if you chose a 4-stroke for this model).
Flys awesome as we know this airframe does.
