 need help for take off j3 cub >
Old 05-14-2009 | 05:47 PM
Default need help for take off j3 cub
havent done cub as of yet, 40 size cub by h/9 need good info for takeoff.thanks
Old 05-14-2009 | 06:21 PM
Default RE: need help for take off j3 cub
ez in the throttle no back pressure on the elev might need a little right rudder until the tail comes up ez off rudder and add elev
then have fun
Old 05-15-2009 | 12:22 PM
ram3500-RCU's Avatar
My Feedback: (221)
I hold full up on tail draggers during taxi until I'm lined up and in the take off roll. I ease out elevator as speed builds to keep the tail wheel active. After a few feet your elevator should be neutral and the rudder should be able to keep you strait (with a little right rudder as noted). Ease up on power as you ease off the elevator. With the tail now high and a good head of speed, a slight back pressure will get her into the air. If you are transitioning from trainer types with trike gear, just remember to keep full up for taxi, or you will be buying more props. This all is really much easier than it reads, and we are only talking about the first 5 to 7 seconds of a 12 minute flight.
Old 05-15-2009 | 06:47 PM
If you have a choice, take off from grass rather than pavement. Cubs react slower and are more true on grass.
Old 05-15-2009 | 08:18 PM
w8ye's Avatar
My Feedback: (16)
Don't try to pull it off the ground too soon
Old 05-16-2009 | 10:24 AM
Zeeb's Avatar
My Feedback: (41)
You will HAVE to learn that the left stick (on mode 2 tx's) goes left and right as well as up and down to complete your takeoff successfully....</p>
Too many flyers forget about the rudder and you'll need some on takeoff. Anticipate that it will require right rudder, possibly quite a bit if you get too rambuncious with the throttle application initially, then it will gradually decrease how much rudder is needed as the model accelerate as the rudder becomes more effective with speed.</p>
Just take it easy as has been noted.</p>
