 good third >
good third
good third
Old 08-17-2009 | 02:04 PM
rc airplane nut's Avatar
Default good third
First, would a Yak 54 be a good third plane? Second, if so, does anybody know of any .40 to .60 size Yak 54s?
Old 08-17-2009 | 02:39 PM
Eganwp's Avatar
Default RE: good third
All depends on your skill level. My second plane was a 3D Acromaster. Some people would classify a 3D plane as their 5th or 6th plane. If you really want to progress your flying skill, go 3D. A Yak will serve you well.
Old 08-17-2009 | 03:08 PM
opjose's Avatar
A Yak is a great flyer if set up properly.
If you have a multi-rate TX, just set up for lower throw rates for landings, and you'll be fine.
Old 08-17-2009 | 05:07 PM
What is the best .40 size Yak and best .60 size Yak?
Old 08-17-2009 | 05:21 PM
opjose's Avatar
Bigger is better.
A larger plane will also tend to hold your interest longer.
If you can, even consider a gasoline engine 70-80" plane. e.g. something in a 26-36cc sized gasser.
The up front cost for the engine will be recovered in short order by the savings on fuel, while those planes are small enough to use standard higher torque servos.
You'll also love not having to run to an LHS or on-line supplier for fuel... the engine has a built in pump, so once broken in and set, you forget about it... and deadsticks, etc.
Good gas engines can now be had for about the cost of a two or four stroke engine.
Old 08-17-2009 | 08:00 PM
the problem with big is not enough money and I can hardly fit a .40 size plane in the back seat of dads pickup or the trunk of moms car.
Old 08-17-2009 | 08:36 PM
opjose's Avatar
Then go as large as you can afford.
Try to go for what you can tolerate even if you cannot put everything together at once.
Old 08-17-2009 | 08:37 PM
GaryHarris's Avatar
I have a Sig Something Extra on the bench right now. Ill see how that works out.
Old 08-17-2009 | 08:40 PM
so, what would be a good bigger one?
Old 08-18-2009 | 12:04 AM
faulknej's Avatar
My Feedback: (9)
ORIGINAL: GaryHarris
I just got my Tiger 2 today. I'm thinking Somethin Extra for the winter kit build. You going to do a thread on your build?
Old 08-18-2009 | 01:01 AM
forestroke's Avatar
rc airplane nut, what were your previous two planes? and what condition are they in? :-)
Old 08-18-2009 | 06:40 AM
GaryHarris's Avatar
ORIGINAL: faulknej
Naw. This build will be a slow one.
Old 08-18-2009 | 06:15 PM
ORIGINAL: forestroke
Hobbico SuperStar and H-9 Ultra Stick. Also an AbellRC adrenaline foamy. All in good condition. I'm acually not ready yet but I need to be thinking about what i'm getting because of cost. Been flying 2 years and only 2 minor crashes with my trainer and none with my stick. I've flown my trainer alot and my stick 4 times.
Old 08-18-2009 | 11:42 PM
forestroke's Avatar
rc airplane nut... i think you're ready for a yak. as someone said, the bigger the better. but also, there are two very different types of yaks now, the 3D and the scale type. The scale plane will be more robust but the wing loading will be higher. the 3D will be easier to fly but require care since it will be built very light.
i've flown the smallest of yaks, a 15 size from hirobo and let me say... with an ASP30 fourstroke, it flew like an plucked chicken. i'd go with a good light 3D capable yak.
Old 08-21-2009 | 10:30 AM
Thanks, for all the advise. I will probably be getting either a Seagull Yak 54 or Nitro planes Yak 54. I like their price tags better than most.
