Releasing CA Hinges >
Releasing CA Hinges
Releasing CA Hinges
Old 03-29-2002 | 10:32 PM
Default Releasing CA Hinges
I've made a big mistake..... When CAing my flaps on my US40 I made too big of gap [1/8 inch] can I release these with debonder or do I have to cut them??
Old 03-30-2002 | 12:30 AM
My Feedback: (29)
Unfortunately (in this situation) a c/a hinge is like a wick for c/a glue. The glue works it's way all through the hinge then seals it so it will not absorb anything else when the glue dries. I don't think the debonder will stand a chance unless the entire trailing edge is submerged in the stuff. Better to carefully trim the hinges flush with the t.e. and start again with a slot machine (my choice) right beside the original slots. My 2cents.
Old 03-30-2002 | 01:55 AM
Probably easier to cut the current hinges and rehinge with new CA hinges right next to the old.
Earl
Old 03-30-2002 | 02:29 AM
PaulSwany's Avatar
My Feedback: (45)
You might be able to get away with just sealing the hinge line with clear ultracote... or tape.
Old 03-30-2002 | 09:45 AM
I've done this with nylon pin hinges, but probably wouldn't recommend this with CA hinges that have a lot of gap. You may encounter high speed flutter...
FLYBUY, you're best bet is probably to re-hinge at another location.
