Larger Revolver
#876
My Feedback: (47)
NY
RE: Larger Revolver
That's what I did - had about 3/8" overlap on each side, extend the elevator all the way up, and pushed the extra down into the gap when closing the elevator. Seems that it will stay "down" now. Does not make too much "crinkling" noise when moving the elevator, either.
#877
OR
RE: Larger Revolver
Pryor808: Nahhh,,,, Your fine! I might have been having an annal moment there, who knows??? (I've been ragged on before about bashing 'perfectly good airplanes'... My philosophy of 'question everything' goes for airplane design too...) And though not all, most of my "project" planes have turned out better than I planned! (You should see my "Twin Ultra-Stick 60 with with the 46FX engines out front on 'pods' on the fuse (not way out there on the wings) for easy 1-engine flying when 1 quits.) And Microdon2, Youre reading my mind! I have been thinking about an arresting cable set up and using 2 anchored fishing reels with heavy line, and I better shut up now lest ya'll cart me off to the looney bin,,,, Film at 11...
#878
My Feedback: (47)
NY
RE: Larger Revolver
Widet - I WAS kidding about the arresting cable - maybe you're not... - another option - what about some kind of brake? Or set up your ailerons as flaperons (?), where they both come up after landing, creating an airbrake. Could that also include elevators? I'm sure there are ways to do this. Another idea - create a cheap wheel brake - just need a flat disk \ surface on the inside hub and a cylander \ small servo to push an arm against it on both sides. Would be cool to engineer. I'd guess someone has already done this in the jet world.
#879
OR
RE: Larger Revolver
I know you were kidding... But seriously? It's a cool idea about using the fishing reels with the drags set just so, but actually catching the cables is another thing. I chopped the ailerons in 1/2 on my bashed-to-the-max Hobbico Hobbistar MKIII 60 (Magnum 1.20 4 stroke) and made some barn-door flaps out of the inside portion that slow it down real nice, but it is more of a Trainer that lands slow enough anyway. Then again, a large chunk of concrete attached to a line that falls out the back of the airplane has been known to work wonders, but that's just rumor... [X(]
#882
NY
RE: Larger Revolver
Twin ultra stick 60.. with twin 46's. that plane movessss!!!! I was at the field this morning and, a buddy of mine named John Kudrick has a
C-130 with twin 70 4-strokes. We couldn't get one of the engines started. This would have been fun to watch. The plane is a flying brick.
#883
OR
RE: Larger Revolver
What got me seriously interested in Twins was my Dual Ace, God rest it's sole...[X(] Ya wanna talk FAST!!! But no matter what "they" say, the DA was NOT user-friendly on one engine, rolling into a death spiral in the blink of an eye. (enter Taps sound track here...)
Now, the parachute idea has been bouncing around in my head for a while, but the weight-penalty (chute, servo/activator/trap door, etc.) is more than I wanted to pay.
Anyway, ya'll been Great about me getting so far off the subject matter, so back to the Large Revolver, with landing hook, parachute and flaps... Just Kidding!!!
#886
RE: Larger Revolver
ORIGINAL: wjcalhoun
So Mike
Set up your radio to do 'flaperons'; it is straightforward, and will slow landing speeds (at least on FourStars and Extras)
So Mike
True flaps toward the wing root would probably be the most beneficial in slowing the plane down even more. I've heard that some people have also had good luck deflecting the ailerons upward on landings to act as spoilers. This supposedly doesn't have the negative side effects of flaperons and helps the plane slow down. Never done the spoilers myself though.
#887
1 Post
RE: Larger Revolver
Flaperons a bad thing..?this is a first.
Flaperons at as spoilers on the ground but do slow down landing speeds. Iuse them on my Yak 55 10e and they work just fine at slowing down a taper wing aircraft without any adverse effects on handling on the approach.
Programming in Spoilerons is simple as well, i assign channel 5 switch and add in someup elevator to the mix when the switch is flipped.
Lands slow and slows down just nicely.
Going to use the same setup on my Escapade and Stik.
Stik has separate flaps but working the ailerons as spoilerons when increase drag to slow down once on the ground.
I can;t see why flaperons on the revolver will be an issue.
#888
NY
RE: Larger Revolver
TimBle.
Your are correct, flaperons on a revolverare not needed. I am pretty sure they are just kidding (I hope). And, if you guys are being serious, you should have picked up a Senior Telemaster....
#889
1 Post
RE: Larger Revolver
well not sure why flaperons are needed on any aerobat, the wing loading is low enough so just fly them in and they stop rolling pretty quickly.
On planes with higher wing loading like Scale Warbirds I can see the absolute need for flaperons or proper flaps because if you fly them too slow they revert to kit form.
Flaperons on a revolver will work just fine to slow it down even further for landing, but why?
From what I can see, its stall speed is quite low compared to say a Pulse XT or GP Escapade.
\Even cmparing it too a Pilot RC Extra 260 or a Giles 202 it can fly pretty slow and therefore can land slow.
#890
RE: Larger Revolver
If I have a little wind or a lot it is no issue landing, actually very easy when you get used to it but when its dead calm it floats.
I used Jets suggestion of Spoilers and I have to say they are mint when there is no breeze.
#891
RE: Larger Revolver
ORIGINAL: wjcalhoun
So Mike
So Mike
Bruce
#892
My Feedback: (47)
NY
RE: Larger Revolver
I don't think flaps \ flaperons are needed on the Rev 70, as the plane has a nice glide ratio - on approach it pretty much floats in. ANd on the 59" - it lands quicker than the 70, but it's fine. I think this discussion started cause Widget mentioned he had a short runway and we were discussing ways to slow his landings down.
#894
RE: Larger Revolver
ORIGINAL: Slats!
I have to clear a freagan fence and stop it before another fence. Or the other runway clear a fence and stop before the ditch with the river.
#896
OR
RE: Larger Revolver
Collision with moose antlers? Heck! One of my trophy largemouth bass tore off one of my floats last summer, and then I caught him later that week with a hook tied to the remaining float, but he tasted like? Styrofoam!!!
