Sig Rascal 40 >
Sig Rascal 40
Sig Rascal 40
Old 04-04-2002 | 06:08 AM
Default Sig Rascal 40
I finished my rascal.. and i was wondering about glueing the wing halves together, the manual says the joiner can be epoxied
into one wing halve but thats all. Iam not really worried about
space saveing for transport. What about wing integrety ?
Thanks for your thoughts..... B
Old 04-04-2002 | 11:49 AM
My Feedback: (64)
Default Wing Integrity
I have been flying one of these with a Saito 56 fairly aggresively with no glue. So far no problems. I did not think taking it apart was a big deal either but it is nice to be able to put the plane in a smaller car. I think it will be fine but go ahaed and glue it if it will make you feel better. cbk
Old 04-04-2002 | 04:58 PM
Default sig rascal..
Thanks for the reply, i may just leave it like it is, i cant wait
to put it in the air, i have a .52 OS on my plane, do you think i will have enough power ? also while i got you here, did you notice any bad habits on your first flight ? thanks B
Old 04-05-2002 | 11:49 PM
My Feedback: (27)
Bad Habits:
Runs out of fuel while you are flying it and you are forced to land! This thing is a *****cat.
Old 04-06-2002 | 06:45 AM
Default sig rascal 40
Well i started the engine today and it ran pretty good,
i think though i should have got just a bit more clearance
on the spinner back plate, pretty much all set to go.
I may take it out to the club and let some of the pro's
give it a once over to be sure its ready for the first flight.
It balanced out perfect and came out of the building process
nice and straight. The .52 has a lot of pull ! i was tooling around the yard with the wing off and boy it gets right along..!
Iam running a 11 6 apc prop. What prop are you running?
What did you mean by *****cat ? thanks.. B
Old 04-07-2002 | 02:14 AM
Default rascal....
well i took the rascal for a little spin today. Just running up and down the runway. Very nice experience so far . The rascal
seems ready to fly and it dont take much to get it in the air.
I had a little problem with keeping it straight on takeoff runs
but it may have been me, this is my first taildragger...
I didn't press my luck because it was getting dark but i think it
will be fine tomorrow to go ahead and give it a whirl.. BH
Old 04-07-2002 | 02:54 PM
Steve's Avatar
My Feedback: (54)
The Rascal is a very good flyer. Just make sure you put some epoxy around the landing gear joints. It don't take much to pop it off if you don't.
Old 04-07-2002 | 09:56 PM
Default I flew the RASCAL today !
I got a flight in on the rascal...wow..! very nice airplane. !
Old 04-08-2002 | 04:42 AM
Default rascal 4o
I just finished getting the bugs out of my Rascal 40. I have a YS 63 for power. It is like a snake ready to strike! With the YS63 it has no problem doing any manuver except unlimited vertical climbs. However I did have to lower the wing incidence by adding 1/8 of a inch at the back or the fusaladge just below the wing to keep it level with full power. I have a 11 x 6 zinger prop and it has plenty of pull.
Old 04-08-2002 | 03:27 PM
wow... i bet that moves along nicely...
Old 04-08-2002 | 08:28 PM
Yes it was quite a jump from a LT40. Although it has a YS63 on it also with an 11 x 7 three blde master airscrew prop. I am glad that I had that much power because when I got off the trainer cord I came perty close to landing in a akward position. Just pull up elevator and pour on the power and flew right out of trouble.
Old 04-08-2002 | 10:34 PM
I did pretty good yesterday considering i hadnt flown in almost 2 years, i wanted to go today but the wind is pretty bad
so i will wait until tommorow. What radio are you running in your
rascal ? BH
Old 04-08-2002 | 11:12 PM
My Feedback: (13)
Brian,
We'll be there sometime tomorrow also (me and Dana).
Old 04-08-2002 | 11:45 PM
Hey dude.................... ! any idea what time tommorow ?
i have to do the income tax thing in the morning but it wont take
long. Maybe i will see yall there. Take care >>>>> B
Old 04-09-2002 | 12:09 AM
My Feedback: (13)
I think it will be sometime in the afternoon..
Old 04-09-2002 | 12:33 AM
Perfect..... i should be through by then. I reset all my servos like D said and i am curious how it will fly, should be better , i was off some....ttyl BH
Old 04-09-2002 | 04:41 AM
JR Equipment.
Old 04-10-2002 | 01:23 AM
Default Rascal 40
I flew my Rascal 40 last week. I have a YS 63 for power. This plane will do knife edge loops. You have to put in full aileron to nullify the coupling affect but the plane will fly knife edge all day long. You can do most aerobatics at 1/4 throttle and I have airbrakes hooked up and it will slow down to a walking pace on landing. My plane weighs 6 lb. 3 oz. on baby scales. I have an 1100 ma battery pack in the plane. I run a 12-8 APC prop and I run 30 % nitro heli fuel. I highly recomend this pland to anyone. I joined my wings together. I have a pick-up truck and the big wing is no problem.
Old 04-10-2002 | 03:09 AM
Default rasacal 40
I wanted to fly but went to the field and the wind was blowing about 115 mph.....maybe manana...?
Old 04-10-2002 | 10:06 AM
My Feedback: (13)
It's gonna rain.....
Old 04-10-2002 | 10:19 PM
Default rascal 40
I got some flight time in this evening before it finaly rained.
3 5 minute flights, the palne flew great but iam have trouble with
my engine, it runs fine on the ground but starts running eraticly
in the air, when i pull the throttle down to get ready to land
the engine surges. I tried retunin each time but it did the same thing each time. TODD if you see this HELP>>>!
Old 04-10-2002 | 10:23 PM
My Feedback: (13)
BH,
It sounds like your engine is lean. Remember, dont tune it till it's peaked on the ground...If you do it will go lean in the air...
Old 04-10-2002 | 10:31 PM
I tuned the needle valve by goin to full throttle then adjusting the
needle til the motor peaked then opened back up 1/4 turn
i got plenty of smoke, ? also the nipple on the bottom of the engine i checked that and its not clogged... what is this nipple for?, this is my first 4 stroke...?????
Old 04-10-2002 | 10:37 PM
My Feedback: (13)
That tube lets the crankcase vent. It must be clear....And not restricted.
Your problems could be a number of things. It's hard to tell without being there and hearing it....
Old 04-10-2002 | 10:54 PM
Default sig rascal
i agree, could be a bunch of things causeing it...
the crankcase vent is clear, ive only run almost half
of a gallon of fuel through it, maybe it needs to be run some
more, anyhow i'll get it right..... otherwise the palne flew great!
BH
