 Black Fuel from a new engine,normal? >
Old 04-04-2010 | 06:26 PM
xDennis's Avatar
Default Black Fuel from a new engine,normal?
Hello,
I've followed the break in instructions to a T, I ran it eayfor the first several tanks after the brek in an had aout 56 flights. However, i still get black fuel. Does this mean i'm damaging my engine?
At get nice hte snoke at WOTso I now i'm running rich.. I just dont' know abot the black fuel.
Old 04-04-2010 | 07:59 PM
Iflyglow's Avatar
My Feedback: (79)
Default RE: Black Fuel from a new engine,normal?
ORIGINAL: xDennis
Hello,
Check to see that your muffler is tight on the engine, and the muffler itself is assembled tight.
Old 04-05-2010 | 09:16 AM
Like Motorman said. Also is the oil truly black. Look close use a white paper towel and see if it has an Amber color-if so your OK, if not your lean and hot. Try a couple clicks richer and check again. The color should be dark amber but not pure black.
Old 04-07-2010 | 11:50 PM
I had the insides get loose in a muffler and it did what You describe.
