Pondering a Yak
#51
ORIGINAL: DenverJayhawk
If looking for 3D in the 60-90 size, have you considered OMP RazorYak or Aeroworks Prox260 profile that was just released? Aeroworks is $50 cheaper than OMP.
Also, your Saito 100 will simply NOT fly the Yak90 well. It may be able to handle the Yak60, but with similar performance to the way your Edge flew.
#52
My Feedback: (221)
ORIGINAL: kyle1745
First thanks for the info, second my Siato 100 was purchased used with the extra and has never produced long flights. It had a 15x6 prop, and I will have to check the tank size. In the end though a 6min flight was pushing it. In its last flight the engine died on take off after a nice warm up and was running just fine on the ground. This is on a plane that had been flown a bit with no issue. I may try to bench test the engine, but also want to try gas.
Thanks for pointing out the weight difference and I will have to check how much nose weight is on the plane I have I believe it is a bit, but doubt its enough to double the engine weight.
What size are the new gas engines coming out?
http://www.rcuniverse.com/magazine/a...rticle_id=1233
