Art tech yak 54 mode 1 change
hi my friend has just bought an Art tech yak 54 2.4ghz rtf model and ordered it in mode 1, he has spoken to the seller who says he changed it to mode one and he says it should be ok, the thing is the transmitter itself seems mode 1 but when plugged in it is still trying to be mode 2 , i have taken the back off the controller to see if there is a switch to change it as this is the case with my century heli, but there is only four plugs one for each axis so we then tried to change those over but can only get it to work throttle on the right (good) but how ever we put the other plugs the aileron and elevator work together as if they are mixing but the transmitter can no mix,
has anyone changed an art tech transmitter to mode 1 who could help, thanks
