Surging
Eflight 480 Outrunner motor, 25 amp speed control, 1500 ma 3C Lipo.... above 3/4 throttle it surges, and it gets worse as the battery is drained. This equipt was in a different plane (not crashed) before, and it never did this before. Any clues ? Dennis Flora, Red Bluff, CA
Surging is a function of how the speed control is reacting to the voltage on the motor. My guess is that you have a battery that is losing capacity and hence voltage.
It also could be a problem with the motor. Perhaps the bell is out of round. I would also check to make sure you have a sift cutoff programmed into your speed control.
First thing I would try is a new battery and see if this makes it better. If it doesn't get back to me here.
Sal, He has a Lipo, 1500ma, 8C out of his Blade CP helicopter doing this. Does he need a higher C battery ? I checked Tower and there nothing of a larger MA capacity that will fit in the plane, but they do have a 1500ma, 11.1v, 20C that will fit.... Does that sound like his answer ? Thanks ! Dennis
The 3-cell 2070 TP battery is very good. We use them here and also sell a lot of them. It's a very good battery. My guess is that with an 8c battery you may be trying to pull too much current and the voltage is dropping enough for the ESC voltage cutoff to engage. As soon as it starts to shut down the motor the voktage picks up, the motor RPM picks ups, the amperage draw picks up and the voltage drops starting the cycle all over again. Hence the surging.
Still before buying a new battery you might want to test this theory first. Make sure it is the battery.
No, thats makes perfect sense Sal. Turns out that the Lipo in his Blade CP is the only Lipo he has now, and that's the one he was trying to use. When this setup was working correctly in another plane, he had a different Lipo, but he accidentally discharged it way too low and ruined it. I think your theory is dead on. Thanks for the insight. Dennis
Im sure it will be fine with the new battery, but it's $80.00 and he just bought a bunch of stuff for his race car, and needs to check his finances. I had no idea that pistons could cost $100.00 each ! If he was married, his wife would divorse him for sure ! lol
