Kombat Kopter video
First flight today on the KK My first flight on a Autogyro it was very thrilling to say the least but all in all it flew very well video on my web sight.
http://12.207.4.186/INTEREST.HTM
My Feedback: (8)
TX
The video on your site works fine for me
I have just recently ordered a Kombat Kopter. Can you please tell me how you have set yours up mods, radio , engine, etc used and are you using the FMA Co-Pilot?
Nathan
Nathan
Hi,
Built per plans easy to build.
standard servos on all . yes I used the FMA auto pilot on the cyclic only.
OS 70 Surpass 4 Stroke
4 517 Jr servos
1400ma battery
JR R600 reciever
FMA Co-pilot
the only thing i messed up on was the vertical stab when you get the plans you have to build the fuse first and the vertical stab did not fit so i cut it to fit. but when I started building the head assy they told me to bend the screws for the rudder to make it line up.
I guess to set it back away from the blades but it worked fine.
still working on landings try to auto it in it comes in a little hard but im sure thats my ignorance.
Eddy
4 517 Jr servos
1400ma battery
JR R600 reciever
FMA Co-pilot
Eddy
My Feedback: (98)
It works now. I see I'm not the only one that chases their gyro tring to get it to lift. It loked like you had some cross wind on take off and just powered through it.
Yea this was my first flight on a auto very different but i think im going to like it. I believe i need about 4 degrees down thrust in my engine unless they normally climb under power.
Eddy
Eddy
