Making a power supply - a little help
My Feedback: (13)
NJ
So ive been doing some reading on how to make a power supply for a charger using a PC PS. I came across something that mentioned using a regulated switching power supply as shown in the link below would only require wiring to the charger and thats it. Did I read this wrong; is this the case? If so, How exactly would I wire the regulated switching power supply in order to power my charger? Any help would be appreciated as Im just trying to understand all of this. Thanks
http://www.ebay.com/itm/New-12V-DC-3...-/120692623020
My Feedback: (118)
TX
RE: Making a power supply - a little help
These types of power supplies are easy to wire for use and require no modification. Personally I get my power supplies from Digikey. The terminals are typically exposed so mounting this in an enclosure is the safe thing to do.
Bliksem
Bliksem
ORIGINAL: ro347
http://web2.murraystate.edu/andy.bat...owersupply.htm
ORIGINAL: ro347
FL
i got bored and used an old 1stgen xbox 360 power supply and turned it into a rc supply not gonna argue with 16amps of 12v power for free
CA
I bought 2 surplus server PS delivered to my door for less than the cost of that PS.
It is not Power Factor Corrected. Not good if you ever want to power it from a small generator.
These are high quality, PFC power supplies.
http://www.primelec.com/pc-accessori...plies-p9539000
They do take a little wiring to operate.
Excellent thread to do this on RC Groups.
http://www.rcgroups.com/forums/showthread.php?t=358340
Take a look. See if this is something you can do.
