8000mah Dual Core LiPos from MaxAmps.com
Spokane, WA – The 150C Dual Core pack offers the highest performance of any LiPo battery available in the world. Rather than using one 8000mah cell, we take two 4000mah 150C cells and put them together in parallel. By doing this, the power load is split between two cells (cores) instead of one. Each cell has the thickest and lowest resistance tabs available. Not only do you get two cores, but you get 4 tabs instead of 2. This creates a pack with the lowest possible resistance, the highest voltage under load, and the most rapid voltage recovery of any pack we have ever tested.
http://www.maxamps.com/products.php?cat=329
• 50+mph in most brushless setups (7.4 volts)
• True 150C rating
• 48 minutes average run time (8000mah capacity)
• Lifetime Warranty
• 5C fast charge capable
• 100% waterproof
• Built today with factory fresh cells
• Built with genuine 12awg Deans Ultra wire
• We add the connectors and balancing taps for you
• 137mm x 45mm x 33mm, 441g
About MaxAmps.com
MaxAmps.com is the industry leader for high-quality LiPo batteries for air, water and surface RC products. Their packs are made to order same day and are assembled in the USA. LiPo packs come 100% waterproof and include a lifetime warranty at no additional charge. For more information on MaxAmps.com, please visit http://www.maxamps.com or call 888-654-4450.
What is the max constant current that we can safely pull from the pack? (until it is nearly used up)
Would there be an extra charge for no conector and larger leads capable of 500 amps?
construction wise, what is the difference between this and a standard 2s2p?.
I think your competitor just released a 200c lipo... and all you have is 150c??
Are you battery guys serious?
Folks, all ya need is 20c-40c
Would you give me leads and assembly that would allow 500 amps continuous? I wouldn't need any connectors. It would only have to pull about 5000 mah from the pack at about 500 amps. It wouldn't need to use up more than 5000 mah at a time.
Brandon
Poor Brandon just got beat up so bad over on RC Groups he comes over here to try and peddle this crap.
These marketing guys don't have a clue.
Supplies 600AMPS from a little battery you can hold in your hand?
Give me a break, completely impossible, a complete bold face lie.
Do you have any idea what size wire would be required to carry 500AMPS?
HI! This isAndy from Hong Kong Billowy Power Industrial Co.,Ltd which are mainly focus on RC heli Lipo batteries (20C-70C) and RC car Lipo batteries (35C-70C) forfive years.<o></o>
X5 the newest products of our battery which is known for its:<o></o>
1.lightweight<o></o>
2. Reasonable price.<o></o>
3. 500 times long cycle life.<o></o>
4. Excellenct high discharge current. <o></o>
5. Capacity of each type is adjustable and Customized designs are welcome.
[img]file:///C:/Documents%20and%20Settings/Administrator/My%20Documents/My%20Pictures/20110818110715566.jpg[/img]
<o></o>
If you have interests in our products, Please enter into our website http://www.billowy-battery.com/ to know more details<o></o>
skype: andy.qin3 <o></o>
msn: [email protected] <o></o>
website:http://www.billowy-battery.com/<o></o>
