Complete Newb needing help with 3S Lipo selection for Traxxas Rally/Slash VXL
Hi All,
I recently purchased a Traxxas Rally VXL 1/10. It comes with a 7-Cell 3000mAh NiMH (8.4 volts) and I am looking to upgrade to a 3S Lipo. Through reading forum posts, I have a general idea of 2S vs 3S and mAh ratings.
Can anyone give me specs of the most ideal 3S battery specs for this car?
Specs:
Any help would be appreciated.
Coy
Specs:
- Lipo - 3S
- mAh rating - ????
- C Rating - ????
- Volatage - ????
Coy
Moderator
I'd say 5000 MAh with at least a 40C rating. Voltage on a 3S pack is always 11.1V. You being a noob though, you may want to go with a 2S (7.4V) pack to begin with, as I think the 3S would be too much for you to handle right now. Later you can upgrade to a 3S pack. Also, do you need a charger? If so, I suggested one below.
2S pack; http://www.atomikrc.com/collections/...-with-uni-plug
Charger; http://www.atomikrc.com/collections/...attery-charger
Is your speed control programmable for Lipoly cut off voltages, as mentioned you will need a lipoly compatible charger if you don't have one. Lipoly batteries that have been worked hard and or abused have a tendency to catch fire even hours after being put away so do you have something like an ammo box to store your batteries in? Never ever leave them unattended when charging and try to make a habit of charging them outside not in your house.
Dennis
Dennis
Edit
Not explicitly looking for speed. Looking more for longer run times. Due to the prices in Australia, I am looking for a battery and charger set that I can grow into rather than buying 2s now and 3s later. The car has a beginner mode (50% throttle and reverse) which I would utilize until I was ready for full 3s.
I'm not sure about whether 3S is too much in this vehicle since I don't own one. But in most cases, 2S is usually plenty. If you like the speed you're getting with the 7-cell nimh, I'd stick with 2S, unless the car really seems under-geared (like the Axial Yeti Trophy Truck). You should pick up an infra-red thermometer for monitoring motor temps and determining gearing. Brushless motors should not get over 180F, and usually run in the 120-140F range.
Being is Australia, look for Gens Ace Lipos. Good value, good cells, good prices. Pick up a couple 5000mah 2S 50C hard case packs. Lots of punch, run cool, and last for years. I've got packs that are 3 years old and are still holding 4500mah and perfectly balanced cells. NOTE that you'll have to solder on your Traxxas connectors.
