Charge time 10,000mah s2 lipos?
Hi all
Can any tell me how long it will take to charge a 10,000mah s2 lipo?
I am opening a track in Spain near Madrid and will be renting out 2wd slash 1/10 models with these batteries in them.
Thanks in advance for any help.
I'm no expert on wattage and amps, and hopefully someone will jump in and break it all down for you.
Charging at a 1C charge rate (10amps)...in theory it would take an hour to go from 0mah to 10,000mah. But the way LiPo chargers charge (constant current / constant voltage charging method) and what energy you have in the pack will determine length of charge. When I charge a pack at a 1C charge rate, and the pack is at storage voltage, it takes me about 90 minutes to balance charge a pack. Balance charging will use a constant current applied to the battery during the first part of the charge cycle. As the battery voltage closes in on the 100% charge voltage, the charger will automatically start reducing the charge current and then apply a constant voltage. The charger will stop charging when the 100% charge voltage of the battery pack equalizes with the chargers constant voltage setting (4.2 volts per cell). At this time, the charge cycle is completed. This extra time used by chargers to balance cells is well worth the wait to maximize the life and happiness of packs. With a charger set to a fast charge mode, your charging times will be shortened, but not recommended.
Of course, this all means nothing if you don't have a charger, to begin with, that is up to the task of a 1C charge rate for those 10,000 mah packs. And if your packs are able to handle a 2C charge rate...you will need a charger with some serious power backing it.
Hi
Thanks for the feedback.
I need the slashes to be able to complete easily 8 x 5 minute races per hour.More bashing than anything as children will be using them at parties etc.
Would it be possible to charge them at 2c and would you know a charger capable of doing this?
I don't know where you acquire parts from in Ireland or what brands are available to you, but the Turnigy Reaktor 2 x 300W 20A Balance Charger is one of the first chargers that comes to mind for a lower priced charger that will take care of two batteries at once. On the higher end of the chargers...iCharger 308Duo. But, once again, you will also need a power supply to get those chargers "up and running". I would look around and do some homework (as I call it) familiarizing yourself with the specs of chargers that are available to you.
Another thing to consider...maximum size of packs that will fit the platform you plan to run. 'Cause I'm sure there is a big difference in dimensions when it comes to those large capacity packs and if they come in hard or soft pack configurations.
Hi everybody. Sorry, new to the forum and don't know how to create new thread.
I am planning to buy this battery for my helicopter HK 450 pro:
http://www.ebay.co.uk/itm/Lipo-batte...gAAOSwr7ZW5VaR
I am still new on this. You think it is a good option? Looks pretty nice and not expensive.
Thank you for your help.
Daniel
Daniel
Daniel
Daniel
I don't know anything about that brand of battery but the size and specifications are perfect for a 450 size Helicopter,
I generally use 3S, 2200 Mah 40C batteries. The one you listed has a higher C rating so it should be fine.
Daniel
Daniel
