Quick Charge Hobbico Hydra Max
My Feedback: (15)
NC
Yes you can but they recommend apeak charger that is designed for nimh like the Double vision from H9. I have the same and used for a season without any problems. All day on a 1450 and still going. Just dont let them get hot when charging. You should also cycle them at least 3 times after charging them a c/10 BEFORE you start using a peak charger. Use your wall charger at first.
