Triton Charger & Balancer FAQ
Hello, i have a Triton Charger my question is: Does it need a Balancer for a LiPo battery Pack? or The Triton is a all in one solution?
I charge a LiPo 3 Cell 11.1v 2000 mAh 15C battery pack,
If ever, What kind of Balancer you guys will recommend?
Does it require to balance LiPo packs in every charge?
Thanks.
Thanks.
Banned
My Feedback: (9)
RE: Triton Charger & Balancer FAQ
In order to balance a pack you first must have access to the individual cells. The Triton or any other charge can balance the pack by simply charging the individual cells if they show a different voltage (10 mv or more) from the other cells. They should be checked every few cycles, this will give you a better idea of how well they stay in balance with use.
NC, ANGUILLA
Has anyone ever tested the tritons "peak delay at start" function. I can't tell if it works. Mine will end charging anytime there is a drop from peak of anything over 180 millivolts regardless of whether the peak delay is set at 0 minutes or 60 minutes. Thanks in advance for any info.
