Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Quick Question
Old 07-03-2006 | 11:51 PM
Evader ---> MGT's Avatar
Default Quick Question
I just got rechargeable batteries for my nitro truck, but the guys at my LHS gave me a Ni-Cd charger that charges both the RX and TX at the same time but they also gave me NiMH batteries for the RX and TX. Does it matter that it says it charges NiCds? Thanks.
Old 07-03-2006 | 11:52 PM
Default RE: Quick Question
Here's what I got
http://www.wholesaletrains.com/Detail.asp?ID=200403611
Old 07-04-2006 | 08:38 AM
That charger is pretty low current. I hope neither of your battery packs are over 1000mAh and even at that it will take 20hours to charge your batteries. What is the mAh rating on your batteries?
Old 07-04-2006 | 08:52 AM
2400 and 2650. A calculator I used said it will take over 48 hours. But will the charger damage the cells by over charging or something?
Old 07-04-2006 | 09:21 AM
No that charger will not actually charge the batteries. You should charge the batteries at a C/10 (C/20 at the slowest) to slow charge the packs. This means that the charger should output ~250mA to charge each of the packs. Right now you are trying to charge at a C/48.
~ means approximately
