TP 6000 mAh 3S3P conversion to 3X 2000 mAH Batteries
OH
I have a Thunder Power 6000 mAh 3S3P pack laying around that I paid big bucks for, for a 40 sized 3D Plane conversion. I was hoping that I could disassemble the pac into 3 separate 2000 mAh pacs. I would need leads for output and charging, and the little circuit board... Does anyone sell the circuit boards (battery pac co's)??? I think the pack is a 12C, it might be a 15C though...
I would need to put this pack in Parallel, right???
The intenede use is for a 400 sized heli... Just learning to hover, Forward flight, etc... NOT doing 3D yet.
MPB
MPB
OH
RE: TP 6000 mAh 3S3P conversion to 3X 2000 mAH Batteries
I did a search and found a great link http://www.dream-models.com/eco/LipoPack.html that should help me build these packs... Pulling the double sided tape apart will be the tricky part though, and I'll still need the balance strip.
OH
I cut my pack apart... It's a 12C pack that I bought last year. The 3 batteries that it makes will be the perfect size! I'm pretty sure that hovering and some forward flight will be ok with these batteries. I just want to eek out some life from these packs... It was a brand new battery that was never used (bought for a 40 sized plane last year and never finished it).
I still need the wiring for charging... I looked at Thunder Power's website... They sell charging jacks (balancing)... Do I even need a circuit board for the packs, or do the wires go directly to each cell?
MPB
MPB
