first lipo help
first lipo help
I’m about to receive my first electric plane with lipos as the power source. Up till now I’ve been using an old industrial nimh/nicd charger to charge my nimh packs. The charger is very simple but effective. There are only two controls one for the amount of time you wish to charge and another to set the current. Will this charger be suitable for charging lipo packs? I will of course set the current to below 1C, but will I be able to slow charge the packs at say 60mA for an indefinite period like nimh or does the lipo need to be disconnected once charged?
Also as the charger has no processing power to shut off automatically, how will I be able to tell if the pack is fully charged? Do they get slightly warm like nimh packs or is it just of case of working out how many amps you put in the pack?
Any advice appreciated
Stuart
If I do need to buy a charger just for lipos what should I get?
Stuart
RE: first lipo help
Stuart,
You absolutley CANNOT use that charger, get a dedicated Lipo charger, preferably an FMA Cellpro 4S, as it is proving itself to be the safest lipo charger on the market for lipos in the popular size packs, goes for 69 bucks here in the states, I don't know about distribution in the UK.
Before you attempt to use lipo batteries, Please take the time to learn as much as you can, they cannot be treated like nickel cells.
Good luck,
Pete
Good luck,
Pete
PA
RE: first lipo help
Yes second that must use LiPO charger constant voltage output MAX at 4.2V and constant current at 1C or less. Also must balance pack so all cells same voltage for long life.
LiPO DO EXLODE as said nothing about LiPO is the same as NiCD or NIMH.
Rich
Rich
RE: first lipo help
Oh dear, looks like i'll be buying a charger, i was wondering though, I have quite a few lab style power supplies with variable votlage and current on them surely i could set one of them up with the correct voltage and just use a very low current so i could charge the pack overnight. I'm thinking that a slow chrage will ensure all the cells are balanced or is this just wishfull thinking?
RE: first lipo help
ORIGINAL: crazyhaggis
Cheers,
Pete
