A123 & Moli Lithium packs-construction
Banned
My Feedback: (9)
For those of you wanting to use the new A123 or Moli cylindrical Lithium cells, Model Electronics Corporation http://www.modelelectronicscorp.com/ is now offering 'Solderless Power Tube Kits' for the A123 and Moli cells. All 'Solderless Power Tubes' are configured as 2 sticks of cells, side by side.
The 'SPT' design addresses the problem of soldering to the aluminum case of the A123 cells. The steel solder tabs need to be trimmed, as trying to remove them generally leaves small holes in the aluminum case. (not good!)
'SPT' kits that make into 2 cells, 4 cells, 6 cells, or 8 cells are offered.
If you are presently flying with 3 LiPo cells, you should use 4 A 123 cells.
I will be reporting on this product in the March 07 Model Aviation (earlier here).
My Feedback: (18)
OK
RE: A123 & Moli Lithium packs-construction
Hi Red, I am considering using the 2300 ma as a flight pack battery running unregulated into the reciever. Like to know what are your thoughts on this.
Dennis
Dennis
Banned
My Feedback: (9)
ORIGINAL: Delta Mike
Dennis
Dennis
My Feedback: (18)
OK
Hi Red, The A123 CELLS are 3.3 volts per cell 6.6 total. When I take my 5 cell nicad pack fresh off the charger I see 7 volts. So my first flight would be operating around the 6.6 volt using a Standard 5 cell nicad.
Dennis
Dennis
