hanger 9perfect peak charger prob.
TX
I have this quick field charger and when i start to charge both my tran. batt which is at 600mah and my reciever batt. 1800mah the first few seconds the led light would go red with a beeping every second. but when i charger only a reciever or trans batt. separately it works fine or at least i think it works fine. so what could it be? im using nicad batt. and a field box motorcycle batt. to charge at the field.
TX
RE: hanger 9perfect peak charger prob.
never mind folks i figured it out it was that my motorcycle battery was low on voltage thus causing the led lights to turn red dumb of me!! i tested by taking the glow and a screw driver to check out the voltage on that and it was zero so i figured i charge the motorcycle battery up to its max and when i checked again it was full!!
