discharge rate multiplex ln 5014
My Feedback: (18)
I am having trouble on the discharge rate of my multiplex ln 5014. I set it up for my lipo 11.1 volt packs and set the discharge at 1 amp. When it starts the discharge it changes to .4amps. I have tried various discharge rates but it just keeps going back to .4.
Its a great charger but I am a little frustrated with this.
My Feedback: (325)
RE: discharge rate multiplex ln 5014
I don't have the charger, but yes. You may also be able to tell just by letting it discharge and see if the rate increases as the voltage decreases. Maybe could throw an old 5-6 cell nickel pack on there to see.
GA
ORIGINAL: Gringo Flyer
happened with larger Ni packs.......
My Feedback: (18)
I think U dud is right on this one. I have a pack discharging now. When the pack was full it discharged at .40 amps as the pack is being discharge it has increased slowy to .41,.42, and now .44.
I am in no way shape or form an electronics or battery expert but as I understand it as the voltage has dropped the discharge rate increases because it is maintaining max peak watt discharge.
On page 6 of the manual for the LN 5014 there is a chart showing the discharge capabilities of the unit for battery voltages up to 17 volts. It shows .44 A for 11 volts and .41 A for 12 volts. Looks like 5 Watts is about it for the unit which is about what you would expect for a unit of that size and little provision for cooling ( no fins, no fan, etc.). Personally I have no use for high current discharge capabilities and I really like the unit.[8D][8D]............ RJ
My Feedback: (18)
I like the unit too. The only time I need to discharge at higher rate is when I have new lipo packs and I want to cycle them a few times.
I am now having some problems charging lipos. I try to charge those same packs and I put the charge rate on .5amps. The charger runs for an hour and then beeps saying the charge is finished. At .5 amps the packs take about 3 hours to charge back up so I am having to start the charger 3 times per each complete charge.
Any ideas on this one?
My Feedback: (325)
I've read the manual and did not notice a 1 hr safety timer, but it must have one. The only other choice is to increase the rate to 1.5 amps. If you have a battery smaller than 1500 mah then there may be some resistance in the system with leads, battery, connections.
My Feedback: (18)
I was wondering the same thing. Maybe it is setup with the idea to do a 1 hour charge at 1C. Thats why it cuts off at 1 hour as an extra safety feature. I almost never charge my lipos at 1C. I prefer to let them charge at a slower rate.
These packs are from commonsenserc and I am form charging them per their instructions. They say to cycle the packs 3 times before using them. Charging at .5C and discharging at 2C.
My Feedback: (325)
It must have a cut-off of 1 hr. I think what you're doing is the only other way to get the full charge. As long as ending volts is 4.2/cell you are good to go.
