Banana Plug power strip...will it work?
TX
Hey guys. I've been in the hobby for a while but am a little new to this electronics stuff. I've invested in a few chargers recently and I decided to build a banana plug power strip for fun. I thought it would be nice to have something I can plug my other chargers into and run from a single power source. Here is what I did. Got a metal project box and drilled holes for three sets banana plug female ends, an on/off switch, entry hole for wires going to power source and a fuse. I wired everything up and it all seemed to work fine The switch is from an auto parts store and is illuminated so it glows green when the unit is on. The fuse is the same blade type that my field charger and power panel use. I wasn't sure if I really needed a fuse but I thought I'd put one in the unit just to be safe. I only made it to accept three sets of plugs at once. I figured anymore would be an overkill. I've tried plugging in a few things at the same time and there doesn't seem to be a problem. Let me know what you guys think.
TX
RE: Banana Plug power strip...will it work?
Here is a photo of my unit. Honestly, I wasn't sure what fuse to use so I just used the identical one that is required for my Hobbico Quick field charger and power panel.
My Feedback: (18)
Great idea. I cant believe someone hasnt marketed that one.
I run my chargers on a car battery and I just have to clip all my chargers to the battery terminals. This strip would make hookup to a battery or a DC power source a lot more convenient.
Banned
My Feedback: (9)
ORIGINAL: funkworks
TX
picky picky
Thanks Red... I liked going thru your site too. I've been in the hobby for a few years and I've never owned anything other than the standard wall charger that comes with your radio until this year. Last Spring I sprang for a Hobbico quick field charger. Now, I just placed an order for the ICE charger after reading up on all the ones in my price range.
Banned
My Feedback: (9)
ORIGINAL: funkworks
picky picky
picky picky
Then you start charging your friends batteries, your neighbor's dust buster, the kid down the blocks scooter until you finally end up on the battery offender list.
My Feedback: (282)
ORIGINAL: Gringo Flyer
They have.
[link=http://www.rcaccessory.com/index.asp?PageAction=VIEWPROD&ProdID=174]Click here for more information[/link]
Detailed Description
The Power Station is a multi-distributor that can transfer power from a power supply. Organize your wiring and utilize the convienient switches.
Up to 5 units can be connected to the Power Station. Three connectors come with switches and blue LEDs and can be used for units up to 10 Amps.
Two connectors come without switches and can be used for high current units up to 20 Amps. Mid-size alligator clips and 50cm silicon wire are attached. If you have more than 1 DC charger, this is your solution!
As an aside, many of the banana plugs available today are not worth tossing in the trash. I've recently been using plugs from Electronic Goldmine that I've been quite pleased with. They are well built, substantial, have plenty of metal, come in several colors, but are a solder only style. I've slowly been replacing my existing plugs with [link=http://www.goldmine-elec-products.com/prodinfo.asp?number=G16003]these[/link]. I think we have a tendency to invest dollars in batteries, chargers and power supplies and sometimes overlook the hardware to get those pesky electrons from here to there.
BTW, I'm not associated with the company.
NV
Wow.. A box with all those connection points. Great idea. I get the same thing done a whole lot cheaper by using piggybackable (if that's a word) banana plugs.
http://www.radioshack.com/product/in...entPage=search
My Feedback: (282)
ORIGINAL: John Murdoch
NV
ORIGINAL: RC Accessory
Not really. Each port is fused and 3 ports are switched. To some this is a lot of money. The people that have bought it, swear by it. To teach his own.
Banned
My Feedback: (9)
ORIGINAL: Andrew
PA
yea Iam with the stacking too.. all mine are at 3/4 spacing. They come with screw terminals in them, just put the wires in the side and tighten. Then just plug in then plug on top the DMM. etc. mine "Digikey" mostly covered so shorts have not been an issue. Also these make great loaded meters just bend the leads on the resistor and screw in, then I just plug in on top of meter and wallaa my own loaded meter. 100mA 250ma etc got a box full [:@] BUT lately the meters and ICE etc are not the America 3/4 spacing so I cut apart.[>:] oh well hard habits to break. On this subject is Anderson power poles also been addicted too on everything great to separate for current connection. Because if your bench doesn’t look like a bad science experiment what’s the fun.
Rich
Rich
