Ailerons???
Oh my yes, there is always that one special that imprints on us and becomes a favorite and it may not even be the best or the worst.
Now with 2.4 its wonderfull that some of these old favorites can actually fly agine, heck even if they are crude by comparison to the stuff we have now.
I be looking forward to hearing of your special projects HP[8D]
John
John
CO
ORIGINAL: HighPlains
- - - - By the second glitch, suddenly he shoved the transmitter into my hands. My problem was now it's glitches and the fact that every time I attempted to pull up, I throttled down. Adding power made it dive. Thinking about it too long would just freeze me on the controls. - - - -
Naturally after I landed and explained the situation to the guys someone said, "Why didn't you just turn with your rudder?" Well DUH me. BECAUSE I DIDN'T THINK OF IT IN TIME. It's what is called tunnel vision.
My Feedback: (12)
ORIGINAL: pimmnz
Might be easier if you just forget the surface the stick operates, but lets call it 'direction' and 'speed' and 'height'. That way whatever surface controls the direction of the thing gets hooked to the stick that operates that channel, 'Speed' is then hooked into whatever stick controls the elevator, and if you are using an engine, then 'height' just gets plugged into whatever stick operates the throttle or speed control.
I had reversed the ailerons....
#31
ORIGINAL: piper_chuck
So, if my plane is flying straight and level at half throttle and I push the ''height'' stick forward is it going to climb? The answer is maybe a small amount, but it's largely dependent on the type of plane, wing airfoil, etc. The most noticable change is that it's going to go faster. Similarly, if I move the ''speed'' stick, the most noticable change will not be speed, it will be altitude.
ORIGINAL: pimmnz
We do seem to be wandering pretty far from beginner stuff here.
