arf motor
Just bought a P51 Mustang from NitroPlanes, RTF. Doing well so far. Noticed that plane seems to have been built around the motor, in other words, can't see how to remove/replace the motor. I am curious because I want to buy another Mustang, kit form, and use my existing electronics but can't see how I will be able to remove the motor and install in the second plane. Even if I bought the ARF version, the motor connections are too short for the receiver connection.
Does the kit come with a split fuselage where you mount the motor and glue the two halves together ?
Thanx
Andy
Thanx
Andy
Just had a thought...does the ARF version also come with a split fuselage? Otherwise the leads from the motor don't seem long enough!
Andy
Andy
