 Hooking up two elevator servos with Spektrum 7600 >
Old 11-07-2010 | 08:18 PM
cappaj1's Avatar
Default Hooking up two elevator servos with Spektrum 7600
Can someone tell me which channels I'd connect two separate elevator servos to on a Spektrum AR7600? And do I setup those two channels as one on my JR X9303 radio or seperately? Thanks in advance for any help.
Old 11-07-2010 | 08:33 PM
goirish's Avatar
Default RE: Hooking up two elevator servos with Spektrum 7600
use mix 6- set right elevator in the elevator slot. Put the left elevator in aux 2 set values for both at +100%
So the mix will be elev-aux2 guess that is the quick and dirty solution.
Old 11-07-2010 | 09:39 PM
tacx's Avatar
Or, Use a Y harness and plug into just your elev channel. You may have to rotate one of your servo arms 180 degrees. Usually no biggy. No messing around with mixing channels.
Old 11-10-2010 | 03:28 PM
BarracudaHockey's Avatar
Both will work but if you do that you ignore one of the most powerful features of your new radio - Channel mating
Press and hold ENT and turn on the radio
Scroll to DeviceSEL
Set the channel you want to use for a mate to INH (bottom line) lets say AUX2
Go to the WingTYPE menu
Under ELEV press the wheel and it will give you the free channels, select AUX2
Now, when you return to the menu instead of ELE and AUX2 you will have LELE and RELE (Left and Right Elevator servos)
Plug them up that way
Now you can sub trim and set the direction on each servo. In additon, the trim will effect both servos, unlike using a pre-mix where it only is active on the primary channel
