SIG SE question >
SIG SE question
SIG SE question
Old 08-01-2003 | 10:33 PM
Default SIG SE question
Hello all,
I have just started building a SIG Somethin' extra and have a question about it. Is the supplied easy hinges good enough to use or is it preferable to install real hinges.
Anything else worth knowing? I plan on installing a 0.46 TT or OS FX engine. Also I have read the list of tips that pops up when doing a search on Google.
Thanks for any comments
RCfun
Old 08-01-2003 | 10:52 PM
The hinges are fine. Add 1" to the rudder if you want to do KE, and don't be afraid to move the CG back.
Old 08-01-2003 | 11:26 PM
I beefed up the tail wheel area and added a Sullivan tail wheel. I did not like the way the kit one was connected to the rudder. I also beefed up the landing gear area, just in case. About the rudder, what i did was add counter on top of the rudder. I also used new axles instead of the screws they provided. I have a TT Pro 46 on it and it has plenty of power. I also added a stringer under the wind sheeting next to the root. The sheathing is rather thin. I did not want to put a thumb through it.
The kit was a great kit to build and it is a lot of fun to fly.
Bill
Check out the link for pics.
My Sig SE
Old 08-01-2003 | 11:52 PM
Also, try a search. You will get tons of hits about the Sig SE.
Here is one to read.
Sig Se Link on RCU]
Old 08-02-2003 | 02:27 AM
The hinges are fine to use. Used them on my modified kobra that goes 128mph. I didn't modify mine to much just beefed up the landing gear area. I can get a little climb from hover w/ my tt 46 and a 12.25 x 3.75 prop. I wouldn't suggest the pushrods that come with it though. Or the plastic clevices (did I spell that right?)
Old 08-02-2003 | 02:44 AM
FLYBOY's Avatar
I am also putting a sub spar of 1/8 inch sq spruce between the spar and leading edge top and bottom. The sheeting is too easy to put your fingers through. That should help.
Old 08-03-2003 | 01:27 PM
Thanks all for the replies and the pointers to more information. I did not add a reforcing spar under the sheeting of the wing. However I soaked the inside of the sheeting with thin CA which seemed to make it quite regid. As I have allready built one wing when posting I did not have the option to add a spar. I hope the sheeting with CA is strong enough and I will take great care.
It seems like a very nice kit to build. When I got the kit some of the balsa part where broken from what seemed transport. I emailed SIG and they quickly sent me replacement parts at no cost to me (I live in Europe). Had them 3 days after I sent my first email. Great service.
Best regards
RCfun
Old 08-03-2003 | 03:29 PM
FLYBOY's Avatar
RCfun, I added the sub spar under the sheeting not for when I pick up the plane, but for when others do. I had a friend pick up my shoestring the other day and put his finger through the fuse. What a pain eh!
