Balancing >
Balancing
Balancing
Old 08-03-2003 | 04:25 PM
Default Balancing
What is the best method to check the CG ? is there a tool i could knock up or something ?
Many thanks Stedge
Old 08-03-2003 | 04:31 PM
FLYBOY's Avatar
Default Balancing
Put your 2 index fingers under the ballance point and see how the plane ballances. If you need to add lead, set it down, put the lead in, do it again. See all the money you saved on some hokey ballance tool? Been doing it that way for over 27 years.
Old 08-03-2003 | 05:46 PM
MinnFlyer's Avatar
Default Balancing
I buy the same gizmos that Flyboy uses.
Old 08-04-2003 | 12:00 AM
Live Wire's Avatar
Default Balancing
Better that punching hole in wing!
Old 08-04-2003 | 12:48 AM
Default Balancing
hole?
Old 08-04-2003 | 01:00 AM
Nik's Avatar
Nik
My Feedback: (12)
Default Balancing
I use the Great Plane CG Machine!
http://www2.towerhobbies.com/cgi-bin...?&I=LXK259&P=7
Much better and easier to use than the two fingers!
-Nik
Old 08-04-2003 | 04:04 AM
Default Balancing
Don't forget to balance from wing-tip to wing-tip as well. Most people(like myself in the past) focus on the CG and forget about balancing the wing's as this can have a major effect on how the plane performs as well.
Old 08-04-2003 | 04:08 AM
Default Balancing
I clamp two wooden dowels to the edge of my workbench and put a big X on the bottom/top of the wing where it's supposed to balance.
I like this better than the finger method cause it leaves me free to add weight and move it around etc.. while the plane shifts around.
If you try it remember to round off the top of the dowels first so that the plane will actually balance on it and not just sit on em.
Old 08-04-2003 | 09:05 AM
Default Thanks
Thanks for all the tips guys great help hopefully i now have her balanced perfectley .....
