 Any way to remove decals? Tower trainer 40 >
Old 12-15-2010 | 04:27 PM
JimmyZep's Avatar
Default Any way to remove decals? Tower trainer 40
I have a Tower Trainer 40 ARF and I would like to remove the decals/ stickers
if feesable.
Thanks Jimmy
Old 12-15-2010 | 05:07 PM
Default RE: Any way to remove decals? Tower trainer 40
They'll probably just come right off. Lift a corner and pull and see what happens. I've had more trouble trying to keep the decals ON the trainer! If they don't want come off try blasting them with a little heat while pulling.
Old 12-15-2010 | 06:22 PM
Yes, they will come right off with just a little heat from your heat gun (use a hair dryer if you don't have a real heat gun) as you pull on them. A little clean up of leftover sticky from the stickers and you now have a better looking trainer!
Old 12-15-2010 | 09:38 PM
radius1x1's Avatar
Try "Micro Sol" decal remover. http://www.microscale.com/Merchant2/...roduct_Count=0
Old 12-16-2010 | 02:47 PM
ORIGINAL: JimmyZep
if feesable.
Thanks Jimmy
Hi,
Fly it. They will soon fall off!
Merry Christmas,
Colin
Old 12-16-2010 | 03:53 PM
JimmyZep's Avatar
Thanks fellas, Im gonna try it tonight.
Jimmy
Old 12-16-2010 | 04:17 PM
JimmyZep's Avatar
It worked !!!
I just warmed em up with the sealing iron.
Thanks!!
Jimmy
