 ALPHA 40 HELP! Electronics >
Old 12-29-2010 | 09:11 PM
Default ALPHA 40 HELP! Electronics
So my brand new unflow alphadecided to act weird today and still is. No inputs are recognizes and the trottle servo twitces. The receiver does not blink or go on like it did yesterday(soid yellow and full control!) so what the hell happend? I rebound 3 times! and charged the battery 15 hrs to no avail please help before i just go burn the plane before I even start flyin it!
Pappas
Old 12-29-2010 | 09:55 PM
Default RE: ALPHA 40 HELP! Electronics
any pics?
Old 12-30-2010 | 04:32 AM
bingo field's Avatar
I would try unplugging all the servos and rebinding, then plug in one servo at a time. You may have a servo that's getting funky with you. If that doesn't do anything, call Horizon, they will work with you on the phone. They have always been square with me. Good luck. Besides, you have a couple of weeks before flying weather strikes in NJ..
Old 01-02-2011 | 04:50 AM
tacx's Avatar
Sounds like you may have a connector problem. Try using another batt. if you have one, not to check the batt, but to check the connector. If not, check your connector pins on your present batt. Try binding without any servos plugged in. It's a proccess of elimination.
Tom
Old 01-09-2011 | 10:23 AM
Just curious? Did you get it working?
