 fule Refilling system with Cowling >
Old 01-13-2011 | 07:56 AM
Default fule Refilling system with Cowling
Hi Friends,
I have assembled the Harrier 90 3d and dont know where to leave fule refilling tube?
please suggest :-)
Regards
Sidharth
Old 01-13-2011 | 08:07 AM
playntraffic's Avatar
Default RE: fule Refilling system with Cowling
look into a three line fuel tank and fuel dot
Old 01-13-2011 | 08:20 AM
MinnFlyer's Avatar
ORIGINAL: playntraffic
Ditto
If you don't have a 3-line tank already and you don't want to take it all apart, DuBro has a new refueler that I have used several times that works well. I don't like most fuel valves but I have had very good luck with this one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXWDG9&P=7
Old 01-13-2011 | 08:21 AM
where ? i can't see
ArcticCatRider's Avatar
I take the tank, and install kind of the opposite of a vent line. A brass line that goes to the floor, and rear of the tank. I fill, and empty through that line...by means of a dot.
This way my carb line doesn't need any attention. The muffler pressure line I splice, and leave a little long so I can fish it out the bottom of the cowl and disconnect, so I know when the tanks full
Old 01-13-2011 | 08:29 AM
Hi Minn Flyer
I have tank with 3 tubings 1goes into enngine carb,1goes into exaust cylencer, one is for taank refelling <ABOUT THIS i have the ruestion , where i should hang this:-) ?
thanks
Old 01-13-2011 | 08:38 AM
MinnFlyer's Avatar
Pick up a Fuel Dot.
Mount it in a convenient place on your cowl
ID:	1546920   Click image for larger version
Old 01-17-2011 | 05:16 AM
<font size="2" color="#00265e">MinnFlyer</font>  thanks
