 Fuel-Proof Glue? >
Fuel-Proof Glue?
Fuel-Proof Glue?
Old 01-30-2011 | 07:58 AM
Default Fuel-Proof Glue?
I had to glue a hole in my plastic crank-case cover. I used CA glue, do you think that it will hold up?
Old 01-30-2011 | 08:04 AM
CGRetired's Avatar
Default RE: Fuel-Proof Glue?
Do you mean the backplate?
Old 01-30-2011 | 08:14 AM
CGRetired's Avatar
If it is the backplate, and I think it is because I can't imagine anything else being made of "plastic", well, I would remove it, thoroughly clean it in something like rubbing alcohol, let it dry completely, then apply epoxy to the area in question. Not much, just enough to do the job. Let it cure overnight and then put it together. I would also test run the engine on a bench to make sure it's ok.
CGr.
Old 01-30-2011 | 09:01 AM
Hossfly's Avatar
ORIGINAL: ES CONTROL
NOPE!
Old 01-30-2011 | 09:26 AM
This was a hole drilled for a smoke system and after a crash was striped out.  After crash it was C A glued and now I am installing this LA 65 In a Supersporster. What should I do???
Old 01-30-2011 | 10:10 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Agreed, it's unlikely it will hold up.
Follow CGRetired's directions above to fix the hole.
Ken
Old 01-30-2011 | 10:25 AM
Thank you , Ken.
Old 01-30-2011 | 11:19 AM
Glue wont do. A short screw as a plug?
Old 01-30-2011 | 11:20 AM
speedracerntrixie's Avatar
My Feedback: (29)
Order a new part!!
Old 01-30-2011 | 11:24 AM
You can order a new one here for $8.99:
http://www3.towerhobbies.com/cgi-bin...=OSMG0066&P=OW
Bruce
Old 01-30-2011 | 04:05 PM
MinnFlyer's Avatar
CGR's suggestion won't work either - Epoxy doesn't stick well to plastic.
I would tap the hole and put a screw in it. make sure the screw doesn't go in too deep and interfere with the "moving bits" as the Brits would say.
Old 01-30-2011 | 04:26 PM
My Feedback: (-1)
The screw with some Gorilla glue on the threads may work but for the price just order a new back plate.
Old 01-30-2011 | 07:07 PM
I went ahead reinstalled a threaded nipple, and installed the smoke system. The Supersporster 60  now weighs 8 Lbs.
Old 01-30-2011 | 07:13 PM
I was wrong !    7 Lbs.
Old 01-30-2011 | 07:52 PM
Drill a bigger hole retap and plug it
Old 01-30-2011 | 10:07 PM
frets24's Avatar
My Feedback: (15)
ORIGINAL: landeck
Bruce
With a 4c engine this wouldn't be a huge issue as the case has nothing to do with the mixture. With a 2c engine you are playing with disaster to trust any glue on the plastic used in model engines. If the glue fails at anytime during flight you'll suffer a lean-out of the mixture and failure of the engine or a dead stick. Murphy's law says that this will happen at a critical time and you'll lose the plane.
Just get a new part and be done with it unless you are willing to put the entire plane at risk. For a $9.00 part I sure wouldn't risk a $200.00+ plane and associated components. Not so sure I would trust a threaded nipple or plug into the plastic either.
Old 01-31-2011 | 07:22 PM
Its a high mileage La 65  .  It Is fixed .  Without Glue.  Thanks everyone!!
Old 02-01-2011 | 05:03 AM
CGRetired's Avatar
Even when we are wrong.. [X(] we aim to please.
CGr.
