 On/Off Switch question >
Old 05-14-2011 | 05:23 AM
Default On/Off Switch question
I want to install an on/off switch so I can hook up my battery to my esc, and then install my canopy etc, and not have to worry about everything being powered up while i'm prepping for flight. I just wanna be able to flip the switch, check range, etc., then fly. Where would I put the switch in the system? I can only assume between the esc and rx plug, but I would like some definite reassurance. Thanks in advance.
Old 05-14-2011 | 05:33 AM
Default RE: On/Off Switch question
Between the battery and the reciever is where most of the switches I have are, and I didnt put them there.
Old 05-14-2011 | 05:40 AM
Thanks Mike. Thought so, just wanted to make sure.
Old 05-14-2011 | 05:47 AM
With electrics, this can be confusing. You cannot put a switch between the battery and ESC unless it is one which can carry the high current. This would be a switch as large as the ESC with corresponding heavy gage wire. Now, some ESC's come with an arming switch which just enables/disables the ESC and this only switches a very small current but does not isolate the battery from the system; i.e. your battery will run down if you leave it plugged into the ESC with the switch in the "disable" position for a long time, not a problem if you are just using it to keep things safe while you are getting the plane to the flight line.
Old 05-14-2011 | 05:55 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Rodney is right. What you want is called an arming switch. This is what you are looking for
http://www.rcaccessory.com/armingswi...aircraft-.aspx
Ken
Old 05-14-2011 | 06:00 AM
ORIGINAL: Rodney
Im not looking to isolate the battery from the system, just looking for the esc and servos to be inactive until im ready to fly. Prob only be for a minute or so, like you said, til I get to the flight line, then i flip the switch, test, and fly away. Thanks for the suggestions. I kinda like the battery isolation idea as well though. Prob just as easy, just need to buy a couple extra connectors, and solder it up.
Old 05-14-2011 | 09:23 AM
jimmyjames213's Avatar
ORIGINAL: djensen623
ORIGINAL: Rodney
With electrics, this can be confusing. You cannot put a switch between the battery and ESC unless it is one which can carry the high current. This would be a switch as large as the ESC with corresponding heavy gage wire. Now, some ESC's come with an arming switch which just enables/disables the ESC and this only switches a very small current but does not isolate the battery from the system; i.e. your battery will run down if you leave it plugged into the ESC with the switch in the ''disable'' position for a long time, not a problem if you are just using it to keep things safe while you are getting the plane to the flight line.
what you are asking for is a battery isolation, their is no way to power the esc and servos but not have them do anything, you could have your reciever off but i dont recommend that at all.
now if you want your servos active, just not the motor, put the switch on one of the motor wires and that will keep your servos free to move, just not the motor
Old 05-14-2011 | 10:28 AM
opjose's Avatar
Some ESC's come with a "arming" switch that only controls power from the BEC to the electronics.
If your ESC doesn't come with one, you could always disable the on-board BEC, then hook up a separate BEC via a switch.
That way your ESC is powered up when you hook up the battery, but the TX remains off and inactive until you flip the switch.
IMHO this is more grief than it is worth ( I'd go with an arming switch first )...
Your ESC probably already has it's own software "arming" proceedure. That is what I typically rely on.
Remember the Arming switch and BEC switch both introduce "points of failure".... heh...
Old 05-15-2011 | 07:12 PM
Charlie P.'s Avatar
ORIGINAL: jimmyjames213
It is possible to power the servos with a seperate battery system - removed from the receiver battery. But it is impractical for most situations. You have to isolate the servopower leads and route them to a seperate circuit. They get the signal input from the receiver but the power from a seperate battery source. Usually it's the giant scalebruisers using 175oz-in servos &up.
Old 05-16-2011 | 03:55 AM
CGRetired's Avatar
If this is a brushless application, you just cannot isolate the motor by adding a switch to only one lead to the motor. Since the system is a three-phase "pulsed DC" application, you might do damage by opening up one segment to the motor.
CGr.
