 Engine Mount >
Engine Mount
Engine Mount
Old 08-28-2011 | 08:27 PM
Default Engine Mount
I have a You Can Do airplane that’s almost complete. I decided to put another engine in the mount that already has the holes drill. They are overlapping each other that will make the hold much bigger the normal. Is there a fix for this or do I have to by another mount?
Old 08-28-2011 | 11:45 PM
My Feedback: (13)
Default RE: Engine Mount
a typical nylon mount is about 5$ for a YCD its a cheap replacement part
drilling over sized holes in the nylon mounts weaken them quite a bit save your self the agony of a broken mount and just get a new one
Old 08-29-2011 | 07:33 AM
I think Tim is correct...I'd get a new mount
Old 08-29-2011 | 09:07 AM
opjose's Avatar
Then if the new mount's firewall hole position differs from the original mount, remove or drill out the existing blind nuts, and epoxy in a "plug" made from a standard wood dowel.
Make sure the plug sits level with the firewall back and front... I normally make the front a bit longer and work the plug into position so it sits flush with the back of the firewall.
Once the epoxy dries I'll use a Dremel sanding wheel to make the front of the plug even with the firewall.... once done you can drill new holes as needed.
Old 08-29-2011 | 09:43 AM
carrellh's Avatar
The plane came with a GP Adjustable mount. There are 5 different sizes.
http://www3.omnimodels.com/cgi-bin/W...SM&C=GMH&V=GPM
The dimensions are listed in the tech notes. If you buy the same size that came with the plane you will not need to redrill the firewall.
Old 08-29-2011 | 10:36 AM
Didn't know that they were so cheap so it make since to just get another on. Thanks to all for your quick responds.
