 fireproofing? >
fireproofing?
fireproofing?
Old 11-30-2011 | 01:26 PM
Default fireproofing?
Do I need to fireproof the fuel tank compartment? if so can Iuse 50/50 epoxy alcohol mix?
Thanks</p>
Old 11-30-2011 | 01:38 PM
My Feedback: (118)
Default RE: fireproofing?
Do you mean fire proofing or fuel proofing? It is recommended practice to fuel proof the firewall and fuel tank area to prevent contamination of the wood if a fuel leak occurs. There is no way that an epoxy mix will help fire proof anything.
What are you trying to achieve?
Bliksem
Old 11-30-2011 | 01:56 PM
KitBuilder's Avatar
Also fuelproof from the firewall forward.
Old 11-30-2011 | 02:49 PM
I meant fuelproofing. Can I use epoxy alcohol mix.
<br type="_moz" />
Old 11-30-2011 | 02:56 PM
JohnBuckner's Avatar
ORIGINAL: luciuswillson
<br type=''_moz'' />
Yes, five minute or thirty minute and I drip in enough drops to turn the mixture milky in color and untill it will drip off the brush easily.
I use plain old garden variety rubbing alcohol. Has never failed to set for me.
John
Old 11-30-2011 | 06:24 PM
MinnFlyer's Avatar
Ditto to what John said
