 Help With Plane Name and CG >
Old 02-25-2012 | 01:12 PM
Default Help With Plane Name and CG
Hi All Great forum
First question can you name the plane?
Help me find where the CG should be to start?
Plane specs are Length 30" wingspan 36"
the plane is tail heavy just a little when the CG is around 2 " from leading edge if it looks ok than ill leave it no weights on yet
The plane is a old art that friend started and couldnt finish and trying to finish it for him
any other questions and comments are welcome
Thanks John
ID:	1731770   Click image for larger version
ID:	1731771   Click image for larger version
ID:	1731772   Click image for larger version
ID:	1731773   Click image for larger version
ID:	1731774   Click image for larger version
Old 02-25-2012 | 01:43 PM
JohnBuckner's Avatar
Default RE: Help With Plane Name and CG
Tequila Sunrise as sold by Hobby people in the past.
Flys well if you balance at the quarter chord or 25% mean aerodynamic chord, measured at mid span (thats half way between the fuselage side and the wingtip.
These airplanes did not seem to last long and beleve it was because folks commonly tried to fly them at 30% and that airplanes dos not fly well that far back.
John
Old 02-25-2012 | 03:04 PM
CARS II's Avatar
My Feedback: (7)
Yeap!
Tequila Sunrise, fallow the instruction John has given you, I remember I had to come in hot then just over the runway close the throttle for a perfec landing [&:].
Practice some slow flight up high to get used to the stalls.
Have fun with it
Old 02-25-2012 | 03:08 PM
CARS II's Avatar
My Feedback: (7)
Found some info for you here on RCU
http://www.rcuniverse.com/product_gu...cfm?kit_id=338
Old 02-26-2012 | 09:52 AM
Thanks John and Cars
I will measure the aerodynamic cord later and make sure it is around the 25% you suggested
And thanks for finding a review for me that's real cool
Thanks Again John
