Idle Problem with my TT Pro 46
Don't spray anything in it. There is always some castor oil left in the engine after it runs, and that is plenty to keep it lubed for it's next start. The tightness you feel is the pinch of the cylinder at the head when it's cold, which is exactly what it is supposed to do.
Hi!
Please!!! It's no nitro engine. It's a glow engine!
Do not take it apart unnecessarely. As has been said earlier, the "pinch" you feel when you turn the engine over is normal, should be there! If not the engine would be worn out!
The pinch is because the cylinder liner is wider at the bottom and tighter at the top,which means the piston gets a better fit at the top.
That's the whole point with modern ABC , ABN and AAC engines...That's why they deliver more power than a ringed engine!
You are far to anxious to start takeing the engine apart, stop doing that. I have far to many fellows come to me with engines in peices and determained that there is something wrong when in reality the is nothing and this often agrivated by these forums.
When receiving a used engine if there is no rough turning crank the first thing to do is run it not start stripping it. Perhaps if it was in a dirt bath yes but not with every engine period.
This whole thing about your berings and rusty crank while it could be true should not be stripped down unless there is a tangible problem that is identifiable simply by a rough turning feel to the to the crankshaft after top dead center. Some discoloration or even rust on the crank journal is often present when there is no real bering rust problem.
As the fellows have indicated about the 'pinch' this is typical of all ABC and ABN engines and what the purpose of this is: The cylinder is actually taper bored with it smaller at the top than it is at the bottom. What this does is when it gets hot the Bronze sleeve will will expand a greater rate than the aluminum piston and the tight fit at the top of the cylinder will open slightly to the perfect clearance to maintain the best seal possible when the engine is hot.
Now with new engines when cold you can feel this interferance fit if you turn it over by hand, Perfectly Normal' and you should avoid unneccessary turning it by hand, when cold and dry untill ready for starting.
John
John
wow !! okay .... thanks alot guys for all the help ! ... was great !!! would have had to replace my glow engine if it wernt for you fellows !!!! hahaha
thanks again !!!
thanks again !!!
On the electric starter question? Yes you need one and thats always what I tell the new folks. various hand start techniques can come later but the internet is not the place to learn that. Learn that from your mentor (the neighbor) later unless of course you want to look like most of the old modelers I know with all our fingers not really pointing in the direction we started with
Also make sure the neighbor is around when you try starting and tuning the engine agine. Take it over to his place or whatever.
John
John
