 Which Iron ? >
Which Iron ?
Which Iron ?
Old 08-19-2012 | 08:24 PM
JohnBuckner's Avatar
Default RE: Which Iron ?
ORIGINAL: carrellh
Yes, that is a good set.
Dittoos that set will work fine and thats no
BS! What is BS is individuals calling all opinions that do not neccessarily agree with their Opinon, BS. Now that is truly BS.
John
Old 08-19-2012 | 08:47 PM
wahoo's Avatar
My Feedback: (59)
<span style="font-size: medium; "><span style="font-family: 'Comic Sans MS'; ">Once more, "to each their own". I'm not the one telling someone that using other than what you use <span style="background-color: rgb(251, 252, 255); ">will cost them much more in ruined covering films</span></span></span> <span style="font-family: 'Comic Sans MS'; font-size: medium; background-color: rgb(251, 252, 255); ">in the long run</span><span style="font-size: medium; "><span style="font-family: 'Comic Sans MS'; ">.</span></span>
Old 08-19-2012 | 09:36 PM
ORIGINAL: JohnBuckner
But I beleve repurposed covering tools are a mistake That in long run will cost you much more in ruined covering films.
John
Let me help you since this line is the one that angers you. The "But I beleve" phrase means its my opinion so indeed yes I agree with you Sir "to each his own". In addition I certainly am the one that wrote that line
However I am not the one accusing everyone of BS who you happen to disagree with.
Good evening
John
Old 08-19-2012 | 10:48 PM
ORIGINAL: wahoo
<span style="font-size: medium; "><span style="font-family: 'Comic Sans MS'; ">Hi BillinIndiana,
Welcome to RCU.
A word to the wise if you plan on frequenting these forums here on this site. You will gain a lot of useful knowledge but you also have to learn to weed through the BS.
I've used a small travel iron for many many years and to be honest the only reason I own a </span></span><span style="font-size: medium; "><span style="font-family: 'Comic Sans MS'; ">topflight iron</span></span><span style="font-size: medium; "><span style="font-family: 'Comic Sans MS'; "> and </span></span><span style="font-size: medium; "><span style="font-family: 'Comic Sans MS'; ">trim iron</span></span><span style="font-size: medium; font-family: 'Comic Sans MS'; ">is from buying out someone who was getting out of the hobby and both are the economy versions, if my travel iron didn't give up the ghost I'd probably still be using it for the reasons already stated. More control, bigger footprint and less wrist fatigue. To each his own.
</span>
I'm not real sure what a "Travel Iron" is ? Is it like a regular clothing iron just smaller or what?
Old 08-19-2012 | 11:35 PM
eddieC's Avatar
Joecool, <div>We're talking covering irons, not soldering irons. </div><div>
</div><div>BillInIndy, that's a fine combo. </div>
Old 08-20-2012 | 04:22 AM
  #31
rgburrill's Avatar
ORIGINAL: BillinIndiana
I have a regular Wagner heat gun, it's meant for paint stripping, but has a high and low setting. Will this work ?
<br type="_moz" />
I've tried it and don't recommend it. I also tried the hair dryer and don't recommend it either. Then my wife got a polymer clay heater and it was the same is the Hobbico (?)Heat Gun and I've been happyw ith it. However, I have been using a standard clothes iron for over 10 years and have been very, very happy with it. I just had to keep it away from my daughter!
Old 08-20-2012 | 06:43 AM
  #32
ORIGINAL: KitBuilder
FYI.... if you get color on the shoe (which you will - generlaly means iron is to hot)... a bounce dryer sheet removes it. Just rub the hot iron on it a couple quick times... and it smells good too . Also... an eraser.. from a pencil.... will remove color that gets on the ultra or monokote from iron as well. For example.. red on your iron shoe and you don't know it.. and you switch to white covering.
If you use a "iron sock" on the iron, you avoid the problem... Well, at least it works for me. I use a H9 monocote iron.
Gerry
Old 08-20-2012 | 10:17 AM
  #33
My Feedback: (-1)
That's a very good set. Without spreading too much BS I will tell you I have tried a heat gun to tighten up covering, I can do it, I have also been using shrink covering for several decades and have a good idea of how to do things. How I cover most beginners could never do. The paint stripping guns are so hot I used mine to light my smokes when I was really stripping paint with it. It's not a good heat gun to use for covering but you may be able to get away with it. I would bet against it though. I have used my wifes hair dryer to show someone it could be done. I did it with Ultra, not Mono, Mono can be a bit harder to work with, it uses higher temps.
If there are no club swap meets happening in the near future then shop around and buy the set, they last about 20 years or more with constant use. I have used my heat gun a lot in the last week or so. I use it to remove parts that were installed with epoxy, heat loosens epoxy so you can remove things without breaking them. Something like that your paint stripper may be better at?
As a builder it's nice to have the correct tools for the job. BS or not BS, make up your own mind.
Old 08-20-2012 | 11:29 AM
  #34
Just for giggles I thought the fellows would enjoy these photo's.
It is not my original iron as I was hard core old school in covering methods quite late up to around 15/16 years ago. Now I would never go back beyond perhaps a nostagia project on occassion.
I suspect this is the first for the purpose hobby sealing iron sold by H.J. Dowd Co. of Cambridge Mass. Still works well and the trade name was Super Sealer.
I beleve it dates roughly to the late sixties about the time Monocoat was also introduced. Notice the cotton AC cord [8D]
John
ID:	1793568   Click image for larger version
ID:	1793569   Click image for larger version
Old 08-20-2012 | 12:06 PM
  #35
+1 for the Coverite iron.
Been using one for more then ten years and I love it. much better then standard iron Tower sells.
Get several socks for it. They do make a difference IMO.
Also, I use a Top Flight Trim Seal tool for all edges...
http://www3.towerhobbies.com/cgi-bin...?&I=LXHZ28&P=7
I use the small iron to tack all the edges then go over the large areas with the standard iron, then use a heat gun for the final shrink.
Bill S.
Old 08-30-2012 | 07:13 AM
  #36
I've found the top flite one very good with only one drawback, you have to unplug it to turn it off but other then that it is good.
JM
Old 08-30-2012 | 11:41 AM
  #37
Even if all irons had an off position, i would still unplug them!
better to be safe then sorry...
Bill S.
