 Thicken Epoxy? >
Thicken Epoxy?
Thicken Epoxy?
Old 10-21-2012 | 01:39 PM
drube's Avatar
Default Thicken Epoxy?
Hi Guys, I'm looking for something to thicken up epoxy so it doesn't run,more like a paste/filler. I've read that microballoons makes the epoxy weak so what else can I use? I read about a product called Cabosil but can't find it locally.
Old 10-21-2012 | 02:19 PM
acerc's Avatar
Default RE: Thicken Epoxy?
Fiberglass such as Greatplanes Pro milled glass will thicken it up. But any additive will also speed the cure time. I personally like System Three's Gelmajik. It is an epoxy that when mixed is a gel. Wherever you put it-it stay's.
Old 10-21-2012 | 05:27 PM
drube's Avatar
Will the milled glass stop it from running?
Old 10-21-2012 | 05:35 PM
acerc's Avatar
Not totally.
Old 10-21-2012 | 05:53 PM
West Systems sells a Silica additive. It's labelled as an Adhesive Filler. You use it just like microballoons. It is supposed to make the epoxy itself stronger than microballoons.
Nothing I've ever used completely stops epoxy from seeping a little bit out around the edges. I've mixed the silica into the epoxy until I had a paste and packed it. There was still some epoxy that'd separated out around the edges. I simply turned the fuselage upside down and it migrated back. Checked about the same amount of time later and didn't see any.
The silica definitely shortens the pot life. That makes it easier to keep from running.
carrellh's Avatar
http://www.epogrip.com has paste epoxy
Old 10-21-2012 | 06:04 PM
drube's Avatar
Thanks guys, The West system sounds like what I need. Do you have a link to the Additive daRock?
Old 10-21-2012 | 06:47 PM
drube's Avatar
I found it Thanks again!
Old 10-21-2012 | 07:10 PM
Charlie P.'s Avatar
Colloidal silica is best.
If you have a table saw take a scoop of the sawdust from under the table.  Works great as a filler additive.
If you want more info, read the link.
http://www.systemthree.com/reslibrar...Epoxy_Book.pdf
Old 10-21-2012 | 07:14 PM
frequent flyer's Avatar
Cabosil  is all you need to thicken epoxy or resin.
Old 10-21-2012 | 08:08 PM
drube's Avatar
I tried to find Cabosil locally with no luck, but the west systems stuff I can find here at west marine.
Charlie,thanks for the link. Lots of info there.
Old 10-22-2012 | 05:21 AM
Rotten40851's Avatar
Try www.mudhole.com they sell paste epoxy, it's what we use on hand wrappedFishing Rods.
Old 10-22-2012 | 05:22 AM
I believe they are in Florida as well
Old 10-22-2012 | 05:43 AM
MTK
ORIGINAL: drube
DRUBE,
Look up "FUMEDSILICA" on the internet. You should get 100's of hits which will include Cabosil and a bunch of other trade names. Fumed silica is an excellent thickener, possibly the best. Fumed silica is extremely lightweight and fluffy and it should be mixed in a container with somewhat tall sides to keep it all together
Another approach for your project is to use JB-Weld. It is ready thickened as it comes from the tube. Good luck
Old 10-22-2012 | 06:53 AM
Sport_Pilot's Avatar
Is this for balsa and wood? If so then the bond is stronger thant the wood even with the microballons. That is unless you use to much microballons, but that would be true of any filler.
If for fiberglass and other composits, it depends on what you are using it for.
Old 10-22-2012 | 09:33 AM
drube's Avatar
Thanks guys.
It's for a fiberglass fuse and light ply formers.
I picked up some West System 406 Colloidal silica adhesive filler. Will try it this eve.
Old 10-22-2012 | 10:40 AM
IVE BEEN USEING BABY POWDER FOR YEARS NOW WORKS GOOD
Old 10-22-2012 | 10:52 AM
SCALECRAFT's Avatar
My Feedback: (13)
What ever you use, wear a good quality respirator.
Steve
Old 10-22-2012 | 11:34 AM
ORIGINAL: SCALECRAFT
Steve
That is true, one can easily change a lot of things in life, lungs is not one of them...
Gerry
Old 10-22-2012 | 01:02 PM
MTK
Steve
For fumed silica?? A respirator is something you want to use for volatile solvent based materials like paints and such.
A simple dust mask will work fine for dusts like carbon, silica, micro balloons and milled glass. Plus it's not like one is going to use this stuff by the pound. A teaspoon here and there is all it will take.
Disposable gloves for working with epoxy is a good idea. But again, unless you are working with the stuff constantly and in large amounts, the vast majority of us will never have a problem with sensitization to epoxy resin. Let's use some common sense here....
There are times to truly be cautious and send that message to beginners and there are times to not do that. Not everything we do in aeromodeling is dangerous
Old 10-22-2012 | 01:07 PM
drube's Avatar
Thanks for the advice guys. Baby powder, that's the one I forgot about. I'll remember that next time.
I just got finished using the 406 adhesive filler.. That stuff is great! Just what I was looking for! Yay!
Old 10-22-2012 | 01:10 PM
CSTSALES.com sells colloidal silica used for thickening epoxy....To maintain structural integrity, do not use microballoons.
Old 10-22-2012 | 03:11 PM
Airplanes400's Avatar
My Feedback: (349)
Just go for the good stuff and stop playing games or cutting corners.
http://shopbvmjets.com/zencart/index...products_id=16
Old 10-22-2012 | 05:41 PM
SCALECRAFT's Avatar
My Feedback: (13)
ORIGINAL: MTK
Steve
With fluffed slilica I don't want to screw around. Silicosis is lung cancer from silica dust. With all the other contaminates in the air, why risk it.
The respirators' function is based on the filter element one has put in it. Not the mask. It has a far less probability to allow leakage form where it contacts the face. Plus I the fluffed silica is a very small particle. The respirator can remove extremely small particles. There is a rating I do not remember right now for particulate filtration . I use the one that removes the smallest of small particulates.
Steve
Old 10-22-2012 | 07:22 PM
Charlie P.'s Avatar
I suppose if I was fiberglassing a boat (again) I would worry about resperating amounts of colloidal silica.  If I am measuring out tiny amounts with a Popsicle stick to mix up a 50cc batch I wouldn't be too concerned.
Sanding it is MUCH more likely to release it into the atmosphere than mixing it in with epoxy.
